So, it works, that is the main thing. The next steps to take are:
- Put all components onto a proper circuit board.
- Add velcro to diffuser sheet (mabye add another one on the inside).
- Add a clock.
- Try some 60 LED/metre strips.
- Do something better with the buttons, brightness up/down buttons for example.
- Look at touch sensors again, probably using a dedicated chip.
- Add a mini desklight extension.
- (in the future) Tie it all into a room network using WIFI/Zigbee or something similar. (This will enable such features as 'Sunrise alarm mode' to be in sync accross all the lights in the room.)
