I noticed that the RTC alarms were failing to put the ornament into sleep mode whenever light patterns that depended on Timer0 interrupts were on. I figured that this may be due to the fact that the Timer0 held priority over the RTC alarm interrupt and consequently it could not be pre-empted by an RTC alarm interrupt if they coincided.
I updated the program to shift the Timer0 interrupt to a low priority and the RTC alarm to a high priority.
Initial tests show that this solution seems to work, but I have yet to test it with the intended time sequence (4 hours on, 20 hours off).
I have a few other optimizations I can perform left, such as getting rid of the modulo operations and replacing them with conditionals. This would decrease the program size at the expense of data memory, which I have plenty of left.
Zachary Murtishi
