Week 4 (Hall Effect Sensor)
A project log for Emergency Bus Button
A button in a bus that notifies the driver if you feel unsafe or possibly in danger.
trevor-andersonTrevor Anderson 04/21/2025 at 17:140 Comments
We wired and coded the hall effect Sensor to notify a screen when a button is pressed. The button will notify the driver of the bus saying "Seat _ needs help" depending on what button at which seat is pressed.
