Ready to begin OS development
A project log for MOD68
Modular 16bit retro computers using cheap 4-layer 100x100mm PCBs
photondreamsphotondreams 01/11/2026 at 17:430 Comments
MOD68 is alive and kicking and ready to start development on what will eventually morph into Amagaki OS once I figure out how all the new chips work and assemble the larger board.
For now, on MOD68 we have :
- A bootloader with interrupt-driven UART that accepts programs using XMODEM-1K (with CRC)
- A loadable firmware updater that also accepts a new firmware image using XMODEM-1K and writes to flash
- A GDB remote serial protocol handler active on UART channel B, with source-correlation, tracing and breakpoint support
- Full integration of debugging in vscode
- MOD68-LA, a logic analyzer interposer board that provides 64 signals to the logic analyzer while replicating the expansion connector. This lets me capture and view all bus activity in real time.
- A 10ms system tick timer using the UART's timer
- A 100 page draft of the OS design document
Time to get coding!
