Preliminaries: what is  XRP?
XRP is a robotics kit created by consortium of several organizations, including Sparkfun, Worcester Polytechnic Institute, FIRST, and many more; see https://experientialrobotics.org/. It is primarily intended for use in education.
It has been in beta for about 2 years, but recently (March 2025) they released version 1, which has significant improvements.
Useful links:
Features
XRP is a typical 2-motor small differential drive robot, programmable in micropython. In addition to basic features, it also has:
Main feature of XPR is that it is easily customizable (unlike, say, Zumo, 3pi+, or Alvik). Chassis is 3d printed (and it has been designed with great care), making it easy to modify; there are numerous attachment points for adding extra actuators or sensors.
It also comes with a well-supported library and a whole course curriculum, and the price is reasonable - if you are willing to 3d print your own parts, the rest is just $99, and they offer discount to educators/robotics teams, which brings it down to $73.
Weaknesses
Here are some things I think can be improved. Most of them are inevitable consequence of designing the robot to be cheap and used in schools; some are my own preferences - to each, his own.
Since the whole design is open source, I am trying to modify the XRP to address all of the above.  I'll document the project  here.
My modifications
Better wheels
I made new wheels which work with Pololu's silicone tires https://www.pololu.com/product/3409
They have same diameter as original wheels, so they can be used without any modifications to the rest of the chassis.
Design files are here: https://www.printables.com/model/1275321-wheel-for-xrp-robot-pololu-tires
Display board
This add-on board contains a 135x240 TFT SPI display, 2 user buttons, a large on/off switch, and two neopixels. It plugs into the headers of the XRP controller.
Source files are in github, and full documentation at https://xrpdisplay.readthedocs.io/
Custom chassis
My final modification is creating a custom chassis for the robot. This is work in progress.
Features:
Design in Fusion 360: https://a360.co/43SxnfM
Printable files: https://www.printables.com/model/1286151-small-xrp-frame
You will need:
To power the chassis, you have two options:
  1.  Two 18650 Li-Ion batteries and a holder. You will need to find a holder that provides barrel connector, e..g this one from AliExpress.
  2. Alternatively, you can use a 2s (7.4V) Li-Ion or LiPo battery pack. The pack should be no larger than 70x40x19mm. I recommend using a pack which contains 2 18650 batteries wrapped together,  e.g. this one from Amazon, instead of a LiPo battery pack (which contains soft pouches).
    You will need either to replace the connector (warning: replacing connector on a live battery requires great caution; any mistake can result in fire or explosion) or make an adapter from whatever connector is provided by the pack to the 5.5x2.1 mm barrel jack
Option 1 is easier and safer, but it requires you to remove the batteries every time you need to recharge them, which is annoying. Option 2 allows you to charge the batteries in place.
