Piston plate return analysis
A project log for Water well design 5.0
New kind of water well that doesnt need any power source except weight of people to pull water out from ground up by using pascal’s law.
anteneh-gashawAnteneh Gashaw • 04/29/2025 at 09:33•0 Comments
It is expected that the ground water upon returning to the static water level will push the piston up resetting the system. To verify the return capacity
Assuumptions
       r = 0.9m
      h= 5m
      µ = 0.8
 At static water level the summation of all forces excluding the weight of the person should be zero
Therefore as long as the mass of the piston is less than 7,063.46 kg for standard well, the ground water will push the piston plate. The weight of sheet metal used for a piston depends on the material and thickness. For common materials like steel or aluminum, the weight per square meter (kg/m²) varies with thickness. Steel sheets weigh between 7.85 and 10.21 kg/m².
Since the well diameter here is 1.8 meter giving 2.5 m² and taking the weight 10.21 kg/m² for safety,  the mass of the piston plate will be
m = 2.5m² * 10.21 kg/m²
m = 25.525 Kg
Which tells us the design is safe.
