This is a small piece of python code that assists in drilling PCBs. Fundrill aligns the physical PCB with locations in a .drl file and verifies the data. Afterwards it produces gcode files which can be fed into a gcode sender for the actual drilling.
In order to verify the location of the drill holes I take advantage of openCV. Once the camera sees the hole it can calculate how far off it is from its correct location. Thus in the verification it corrects any anomalies making sure the holes are perfectly drilled.
Details
Drilling a PCB by hand can be a gruelling and time consuming process. In the following video, I go through a more automated process of drilling using Fundrill.
