BU03-Kit Development Board (Hardware Section 1)
——AndyL
1. Hardware Overview
1.1 About BU03-Kit
The BU03-Kit is a UWB development board based on the BU03 (DW3000) module and powered by an STM32F103C8T6 MCU. The BU03 module integrates an onboard antenna, RF circuitry, and power management.
It supports Two-Way Ranging (TWR) and Time Difference of Arrival (TDOA) positioning with up to 10 cm accuracy and a maximum data rate of 6.8 Mbps. Applications include IoT, mobile devices, wearables, and smart home solutions.
1.2 Key Features of BU03
Typical Power Consumption (@3.3V, 25°C):
Mode
Average Current (mA)
CH5 TX @ 0.85 Mbps
17.03
CH5 TX @ 6.8 Mbps
15.06
CH9 TX @ 0.85 Mbps
24.85
CH9 TX @ 6.8 Mbps
22.6
CH5 RX @ 0.85 Mbps
39.81
CH5 RX @ 6.8 Mbps
40.01
CH9 RX @ 0.85 Mbps
49.23
CH9 RX @ 6.8 Mbps
48.05
Instantaneous Startup Current
174 mA
Deep Sleep Current
179 nA
1.3 Pin Definitions
Pin
Name
Description
1
EXTON
External device enable during wake-up; used to minimize power consumption.
2
WAKEUP
Brings DW3000 from sleep/deep sleep to active mode. Tie to GND if unused.
3
RSTN
Reset pin, active low; equivalent to power cycle reset.
4
IO7
GPIO7 / SYNC input; reconfigurable if SYNC not used.
5
VDD
Power input (1.8V–3.6V), ≥200mA recommended.
6-7
VCC
Power input (2.5V–3.6V), ≥200mA recommended.
8
GND
Ground.
9
IO6
GPIO6 / SPIPHA / EXTRXE; SPI phase select or external RX enable.
10
IO5
GPIO5 / SPIPOL / EXTTXE; SPI polarity select or external TX enable.
11
IO4
GPIO4 / EXTPA; external power amplifier enable.
12
IO3
GPIO3 / TXLED; drive LED after transmission.
13
IO2
GPIO2 / RXLED; drive LED during reception.
14
IO1
GPIO1 / SFDLED; LED indicator when SFD (start frame delimiter) is detected.
15
IO0
GPIO0 / RXOKLED; LED indicator for successful frame reception.
16
GND
Ground.
17
CSN
SPI chip select (SPICSn); also used for waking from sleep modes.
18
MOSI
SPI data input.
19
MISO
SPI data output.
20
CLK
SPI clock input.
21
NC
Not connected.
22
IRQ
GPIO8 / IRQ output; active high by default; reconfigurable.
23
NC
Not connected.
24
GND
Ground.
Note : All GPIOs except SPICSn have internal pull-down resistors. SPICSn has an internal pull-up for safe operation when un-driven. Resistance varies with VDD (10kΩ at 1.8V to 30kΩ).
2. About the BU03 Module
The BU03 is an ultra-wideband (UWB) module based on Decawave’s DW3000 chip.
2.1 What is UWB?
Ultra-Wideband (UWB) is a wireless technology that transmits data via very short pulses instead of traditional carriers. The shorter the pulse in the time domain, the wider its bandwidth in the frequency domain — often reaching GHz levels.
Key advantages of UWB:
UWB systems typically follow the IEEE 802.15.4z standard, using Impulse Radio techniques.
2.2 UWB Positioning Methods
Distance-based methods:
Angle-based methods:
2.3 Comparison with Other Positioning Technologies
Metric
UWB
BLE 5.1+
Wi-Fi RTT
RFID
GPS
Accuracy
Centimeter-level (±0.5–10cm)
Meter-level (1–5m)
Meter-level (1–3m)
Meter-level (1–10m)
5–10m (outdoor)
Interference Resistance
Excellent
Weak
Moderate
Weak
Weak indoors
Power Consumption
Low (higher than BLE)
Very Low
High
Low (esp. passive RFID)
High
Latency
Microseconds
Milliseconds
Milliseconds
Seconds
Seconds
Range
Short (<100m)
Medium (<100m)
Medium (<150m)
Short (<15m)
Global
Multipath Resistance
Excellent
Poor
Moderate
Poor
Poor
Typical Applications
Digital keys, AR/VR, industrial automation
Indoor navigation, asset tracking
Indoor location services
Warehouse management, access control
Outdoor navigation
