This is the third iteration of ISS tracking projects I've been making. The issue is that the online services I've been using earlier to track the ISS no longer exist. But as a space lover, I really loved having something that reminded me of the presence of the ISS up there. Also, the ISS is nearing retirement, set to be decommissioned by 2030. So, while it's still orbiting for the next few years, I wanted to admire its presence and identify exactly when it will be flying overhead, so I can rush outside for a glimpse as it quietly crosses the sky above me.
So this final version (probably) of ISS tracker not only indicates when the ISS is overhead, but also how far it is!
Makestreme
If you were to calculate the diameter of a dish antenna required to communicate with the ISS at these frequencies, you'd end up with something over 10 meters wide! That's clearly out of the question for a DIY project, especially one that fits on your work desk.
Aaron
morgan
Robert Wallhead
Stryker295
