Milling two-sided PCBs without alignment pins!
Using the CNC rig itself for position accuracy
Alignment of sides on two-layer PCBs in hobby equipment is often done with
alignment pins. Often getting the needed precision requires a lot of hands-on experience.
This project attempts to get precision enough for 2.54 mil spacing using the rig
itself as a measurement device and then computationally transforming the G-code
to the machine coordinates.
hackaday.txt
The long story including some hands-on instructions
plain - 13.16 kB - 05/06/2025 at 11:37
Download
Figure 1, this describes the translation math for each side of four in a rectangle
JPEG Image - 3.29 MB - 05/06/2025 at 11:39
Preview
Figure 2. This describes where four points on four sides are projected and then the intersection becomes the new coordinate, PT.
JPEG Image - 3.19 MB - 05/06/2025 at 11:39
Preview
transl_copper.c
The program itself, sometimes needs "-lm" added to the compiler line
C Source File - 12.09 kB - 05/06/2025 at 11:54
Download
Detail on how the tool can be <b> carefuly </b> lowered into one of the Alignment holes to obtain the machine coordinates.
JPEG Image - 166.40 kB - 05/06/2025 at 12:02
Preview
View all 8 files
