Circular Breakout Board Carrier —Fits in 100mm PVC Tube
A project log for High-Precision MEMS Magnetometer
for Solar and Subsurface Monitoring
bertrand-selvaBertrand Selva 05/18/2025 at 18:060 Comments
This PCB is designed to host several breakout boards and to simplify the assembly of a device intended to fit inside a 100 mm PVC tube. Its circular shape allows for direct mechanical integration into the lower part of the enclosure, with no wasted space.
Key features:
This approach makes it easy to use standard modules (ESP32, GPS) while maintaining a solid, reliable structure suitable for integration in outdoor environments.
