Milestone 1: Functional Platform & First Data Collection
Make the mechanical assembly work, with two rotational degrees of freedom.
Write or adapt the driver for the PNI RM3100 magnetometer.
Develop the acquisition code and start collecting a first dataset.
Tune the Kalman filter on PC (using MATLAB) with the experimental data.
Implement the Kalman filter (as defined on PC) on the ESP32.
Set up the display using the LVGL library.
Test the device outdoors!
(First milestone: have my own ultra-precise magnetometer.)
Milestone 2: Deep Learning & Real-Time Detection
Collect data over several months.
Train a neural network to correlate, for example, the “K factor” and my experimental measurements.
Deploy the trained network on the ESP32 for real-time inference.
(Second milestone: personal solar storm detector!)
Milestone 3: Power Optimization & Field Robustness
Power management: implement sleep cycles on the ESP32.
Reduce the number of acquisition cycles with movement, without degrading measurement quality.
Bertrand Selva
