5x7 LED panel
A project log for Lightning Talk Timer
LED Countdown timer for short talks with hour glass trigger. Built for Hackaday Europe 2025.
maketveemakeTVee 05/10/2025 at 11:500 Comments
The 5x7 LED panel PCB was designed in KiCAD with 5050 WS2812B LEDs
The PCB is mounted at the back of a 3D printed diffuser using two layers of white PLA as a diffuser.
The pixels are separated with black PLA. Printing is done with color change, so the outer layer is one closed surface.After some first fails, the white PLA was interweaved into the black PLA by enlarging the second layer. This leads to a robust solution and the white PLA stays in place even when pushing on it directly with the finger.
