Here I like to show you how to simply make a pcba test jig with a laser cutter.
First things first: to test a PCBA, I need reliable electrical access. That means adding test points to the PCB during design. I use 2 mm diameter test points to match the small spring-loaded pogo pins (a.k.a. test needles) I have on hand.
You decide whether to place the test point on the top or bottom side. Both has its limitations and advantages.
For the LED PCB example it is only possible on the top side due to the aluminium PCB. And I will not be blinded ;)
I export the outline and copper layers from KiCad (take your EDA) as SVG files, which I then import into LightBurn, the software I use to control my laser cutter. These SVGs serve as the basis for creating the test jig’s cutouts and alignment holes.
The jig is made from three layers of 4 mm plywood, stacked and aligned using M4 screws and nuts. Here's how I configure each layer, from top to bottom:
Top Layer: This layer has a cutout for the PCB outline.
I intentionally leave an additional 0.1 mm margin around the board to avoid a tight fit, making it easier to insert and remove the PCB.
I also added some space for the fingers to grab the PBC easily.
Middle Layer: This is the functional core of the jig. It includes:
Holes for the pogo pins to align with the test points.
Additional cutouts to provide clearance for components, since the PCBA is placed upside down in the jig. In my example only a cutout for the LED.
You might not need cutouts when you place the test points on the bottom layer and you only have top side components.
Bottom Layer: This layer provides clearance beneath the pogo pins, allowing access for soldering wires or connectors to the pins. I added some cutouts to bring the wires back up to the top layer where I use angled pinheaders to interface with the LED drivers.
Thank you for your comment!
You are right, there is plenty of room for improvements. And I like the idea of the laser cut pins!
This is my second test jig and it contains already some improvements. The next one will be even better!
Very nice instructions. I know this is a simple thing that doesn't require overthinking. Still I have suggestions for improvements.
As you are using a laser cutter anyway you could used laser cut pins instead of the the screws. Just make the holes square. The connectors can probably just be simple rectangles 1x4 times the material thickness or something more elaborate with a rounded head and snap hooks on the other side.
The grip holes should probably go through all layers to allow sticking your fingers through for easier gripping.
The lowest layer could have a large tab to clamp the jig to the table.
The last two are probably only needed if you have larger numbers of boards to test and getting them in and our quickly actually makes a difference.
