Serial Interface for a paper tape punch
A serial interface for the FACIT 4070 tape punch with only a DTL-level parallel interface.
The converter project is intended for the FACIT Type 4070 Code 0001 Paper Tape Punch.
This early 4070 is based on 6V DTL logic and only has a parallel interface.
By interfacing an Arduino Nano to the parallel connector (with proper level conversion) a serial interface is added. The board is powered by the 4070.
The project-board interfaces all signals of the 4070, but only a small subset is used in the first firmware. Data can only transferred at 600 Baud, which is slower than the 4070 punch speed. This means no handshake needs to be implemented
The Arduino console is only used for testing, but can potentially (also) be used for data transfer.
FACIT 4070 to serial interface
A serial interface for DTL-parallel-only versions of the FACIT 4070.
Hardware
The converter board is intended for the FACIT Type 4070 Code 0001 Paper Tape Punch. This version is based on 6V DTL logic and only has a parallel interface.
At the back is a 25 pin sub-DB connector (P1), carrying all signal lines, as wel as ground, +6 V and +24 v power lines. Internally there is also the bridging
board connector (K2). For the current interface, the following A and B side connections are shorted: 1 to 8 (Channels 1 to 8), 9 (sprocket channel), 10 (SD),
11 (PI), 12 (PR) and 20 (ERR2).
There are nine channels, eight being the bits 0 to 7 and the last being the sprocket hole. The layout mapped to the paper tape is:
hole channel (top to bottom)
  O 8
  O 7
  O 6
  O 5
  O 4
  o sprocket (smaller hole)
  O 3
  O 2
  O 1
  The input signals of the 4070/0001:
  • PI    - Pulse In
  • Ch1-8 - Data bits
  • Ch9   - sprocket hole
  • SD    - Feed direction
All these lines are buffered by ULN2003 and pull-up resistors to the +6V.
The outputs:
  • PR   - Ready
  • TL   - Tape Low
  • ERR1 - Error
  • EXT  - Ext button
All these lines are attennuated with resistor dividers to adapt the 6V to Arduino save 5V levels.
In the Arduino interface all signals are routed to the Arduino, but the firmware only only uses a subset.
Firmware
The board is build around an Arduino Nano. The only user interfaces are an RS-232c DE-9 female connector and a flatcable to be connected to the 4070 P1 connector (a DB-25). In the board is a 26 pin header for an one-to-one connection to the P1.
For this implementation, a serial BAUD rate of 600 Bd is selected, as the FACIT 4070 can punch a byte within the transfer time of that byte.
The FACIT can punch 75 characters per second, 600 Bd is equal to 60 characters per second. The advantage is that no serial line handshake is needed.
The USB-connection is currently only used for testing purposes. For this a simple command line interface is available. This is the startup
and help text:
Version 1.1.0
Serial start
Paper Tape Punch v1.1.0 Usage:
B  -    Toggle LED
Cc -    Blink channel (0-8,A,B)
        (8 = SPROCKET, A = SD, B = PI)
H  -    This help text
Pc -    Punch character
Scccc - Send string
 A command is terminated with at least a New Line (line feed).
PaperTapePunchInterface.kicad_schV1.1.pdf
Schematic V1.1
Adobe Portable Document Format - 164.65 kB - 05/13/2025 at 18:14
Preview
PaperTapePunchInterfaceDesignV1.1.zip
Kicad design files version 1.1
Zip Archive - 101.65 kB - 05/13/2025 at 18:01
Download
PaperTapePunchInterfaceProdV1.1.zip
Production files V1.1
Zip Archive - 55.98 kB - 05/13/2025 at 18:01
Download
PaperTapePunchInterface.kicad_pcbV1.1.pdf
Board V1.1
Adobe Portable Document Format - 85.11 kB - 05/13/2025 at 18:01
Preview
Paper_Tape_Punch_interface_noHandshake.zip
Arduino sketch
Zip Archive - 2.53 kB - 05/13/2025 at 12:22
Download
View all 6 files
  • Updated KiCAD files
    fjkraan05/13/2025 at 18:12 0 comments
    The KiCAD files are updated to version 1.1. What is build and tested, was version 1.0 and some connection issues were found. These were corrected, but no new boards were made and tested. I expect they work Ok, but have no plan to test this.
    The fixes are:
    - The Rx, Tx serial lines between the Arduino and MAX232 were crossed. As the AltSerial library uses fixed lines, it was not a simple operation to fix it in the firmware.
    - The Rx and Tx lines were also crossed between the MAX232 and the DE-9 (J4).
    - The capacitor C6 is moved from the PR signal to the +6V power supply line.
    - The DTR line is now connected to the HW Handshake Patch block.
View project log
