Simple Weather Station on CrowPanel Advance
A ready-to-use weather station. Quick setup: flash the prebuilt firmware and start testing in under a minute.
A ready-to-use weather station. Quick setup: Flash the prebuilt firmware and start testing in under a minute; no coding is required. Open-source and customizable for your weather-based projects. Firmware and source code available on GitHub.
💡 Why Use It?
  • Testable in under 1 minute
  • Open-source — extend or repurpose for your own weather-related projects
  • Simple and reliable — ideal for both hobbyists and developers
✅ Quick Start in 2 Steps:
1. Grab your CrowPanel Advance
2. Flash the precompiled firmware from GitHub — no setup needed: https://github.com/Grovety/CrowPanel_OpenWeather/tree/main/firmware
 🌦️ Features:
 Current temperature and “feels like” temperature
  • Cloudiness, wind speed, pressure, and humidity
  • Sunrise and sunset times
  • Hourly forecast for the next 12 hours
  • Daily forecast for the next 4 days
 ⚙️ Settings:
 Temperature and pressure units (°C/°F, mmHg/hPa)
 Manual and auto screen brightness control
 Manual or automatic location detection
 Wi-Fi connection setup via touch interface
 👉 Precompiled firmware and source code are available on GitHub: https://github.com/Grovety/CrowPanel_OpenWeather/
meteo_release_0.12.zip
Prebuild firmware. Download, extract, and use FlashTool.exe to flash in CrowPanel.
x-zip-compressed - 9.72 MB - 05/14/2025 at 04:34
Download
  • 1 × CrowPanel Advance
View all instructions
