Hackaday.io Hackaday.io
Sign up Log in
Almost humanoid robot
My attempt at making a fun humanoid-like robot.
tanguyTanguy
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
1.7k views
0 comments
14 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 18
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
1.7k
0
14
12
Team (1)
  • tanguyTanguy
Join this project's team
MISC
ongoing project
humanoid ROBOT servo Motor esp raspberry diy Robotics arduino 3D printed 3d Animatronics design ai wifi assistant
Related lists
Hackaday's Social Media Featured Projects
An easy-to-find list of the featured projects from Hackaday's Instagram.
This project was created on 05/14/2025 and last updated 3 months ago.
Description
How far can I go in building some kind of humanoid robot?
I don't know—but we'll see!
Project Logs
Collapse
  • Metal body - update in progress
    Tanguy • 07/18/2026 at 17:19 • 0 comments
  • A bit of spoil, for the next mechanical upgrade
    Tanguy • 06/08/2026 at 14:53 • 0 comments
    A bit of spoil, for the next mechanical upgrade.
    Butter (the robot) will receive new metal parts for its more sensitive components, such as the body and shoulders. The current plastic parts are under high stress (supporting the whole weight of the body + arms + head). And the faster I make him move, the more afraid I am that he'll break.
    Those metal parts will also allow me to simplify a lot the other plastic parts and make them easy to print.
  • Self-presentation of the robot
    Tanguy • 06/02/2026 at 20:00 • 0 comments
    I thought it could be fun to make him introduce himself.
    Voice is in French, but I have set English subtitles.
  • Last version of the robot doing some moves
    Tanguy • 06/02/2026 at 18:02 • 0 comments
    Demo of the robot doing some moves after last mechanical upgrade.
  • Better IK & control UI
    Tanguy • 05/14/2026 at 12:55 • 0 comments
    I have (as always) forgotten to post a lot of things, but the robot project is going great, here are some news, more coming soon ;)
  • Body motion & arm IK
    Tanguy • 12/16/2025 at 10:16 • 0 comments
    I have made great progress this last week: added body joints (2 DoF) and articulated ears (2 DoF each) to display emotion and make it more expressive.
    In total, robot now has 17 DoF: body 2, neck 3, ears 2 × 2, arms 5 × 2. I had to upgrade the power supply to manage that.
    On the software side, the arm IK is starting to give promising results (it can move the arm just by using x, y, z coordinates).
  • Arm Movement and Strange Eyes
    Tanguy • 07/21/2025 at 10:34 • 0 comments
  • New build !
    Tanguy • 06/24/2025 at 09:46 • 0 comments
  • New Shoulder Design
    Tanguy • 06/20/2025 at 01:43 • 0 comments
    After some testing, I wasn't satisfied with the range of motion of the current shoulder (couldn't lift the arm high enough). So, I reworked the 3D design. Here's what the new version looks like.
    I also embedded more bearings into the 3D-printed parts, to better support weight.
  • It now has a head! (Kinda.)
    Tanguy • 06/04/2025 at 09:08 • 0 comments
    In the past, I’ve created a variant of this robot head project: https://hackaday.io/project/185066-robot-buddy. Instead of using an LED matrix, it uses an old phone as the display.
    So I've added it to this robot.
    (I plan to open-source the “face” app, but it needs a lot of cleanup first.)
View all 18 project logs
Log In/Sign up to comment
Sign up with Github
OR
3D Printed Quadrupedal Robot
Project Owner Contributor
TOPS
aaed-musaAaed Musa
The 2018 Hackaday Prize
This is Quadbot 17, a work-in-progress quadruped robot with 22 degrees of freedom, based on Robotis AX-12 motors and a 3D-printed chassis.
Quadruped robot with 22 DoF
dimitris-xydasDimitris Xydas
The 2016 Hackaday Prize
Zizzy is a personal robot prototype for people with limited mobility. It can talk, show emotions, and manipulate desktop objects.
Zizzy: A Personal Robot Assistant
michael-roybalMichael Roybal
RR1 is an open-source, 6+1 degrees of freedom desktop robotic arm, mostly 3D-printed with joints powered by custom planetary gearboxes.
RR1: Real Robot One - a DIY Desktop Robotic Arm
pavel-surynekPavel Surynek
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Almost humanoid robot", please tell us the reason.
Send message
Remove Member
