Created and Uploaded Pixel 3a XL Case Insert
08/28/2025 at 12:53 • 0 commentsCreated and Uploaded Pixel 3a XL Case Insert for Modular C-Deck to Printables
Two steps back...
08/14/2025 at 09:16 • 0 commentsI took two steps back and created a case that needs to be assembled with glue, and it’s for the Pixel 3XL only. I had to leverage the Pixel 3XL’s thin design to make a really slim case, and I always wanted to print at least one version in Cyberpunk 2077 game colors. Here it is...
Uploaded v3.1.0 and a few smartphones' case inserts
07/30/2025 at 08:46 • 0 commentsUploaded v3.1.0, which supports smartphones up to 13 mm thick and case inserts for the Poco 3, Pixel 7, and Pixel 9 Pro XL, in addition to the existing case insert for the Pixel 3 XL. All files are available for download on Printables.
Started working on a new modular version for phones up to 13 mm thick
07/17/2025 at 18:59 • 0 commentsI completely got fooled by the official specs from smartphone manufacturers claiming their new phones are really thin, around 8 or 9 millimeters. But that only refers to the body of the phone. In reality, the camera bump adds another 2 or 3 millimeters, so the actual thickness is more like 10 to 12 millimeters. It looks like the current design is not universal enough to accommodate popular modern models.
Completed Modular Version 3.0.0
07/15/2025 at 16:16 • 0 commentsI've finished modeling and assembling a new modular design for the C‑Deck. It's no longer the Pixel 3 XL C‑Deck, as it can now fit any smartphone up to 10 mm thick.
Completed printing and assembly for v2.2.0
06/21/2025 at 13:07 • 0 commentsI've printed and assembled version 2.2.0 of the case using PETG. It can't be captured in a photo, but the device feels much nicer to the touch, and the resulting print is significantly more dimensionally accurate.
Design update v2.2.0 - PETG
06/15/2025 at 15:31 • 0 commentsI've updated the device design to make it more suitable for printing with PETG filament. In short, I made all parts of the case thicker to improve its sturdiness. I've also updated the lock slider design to fix the issue of sliders falling out while the device is open.
Completed printing and assembly for v2.1.0
06/05/2025 at 19:11 • 0 commentsI've printed and assembled version 2.1.0 of the case. It needs Velcro ties at least 200 mm long now. I really like how it looks.
Design update v2.1.0
06/04/2025 at 08:29 • 0 commentsAfter a few days of testing, I decided the OTG cable doesn’t need to stay connected all the time, so there’s no reason to hide its connector deep in the case. I also dropped the idea of using cable ties, which made the circular holes (and really the whole original panel design) unnecessary. Built a new version of the case.
Completed printing and assembly of Version 2
05/24/2025 at 17:37 • 0 commentsJust finished printing and putting together Model V2. It turned out a bit more work than expected. I had to do quite a bit of sanding and filing to get the parts to fit right. I tweaked the design and made a 2.0.1 version to fix the worst of it, but it still needs some cleanup after printing.
Sergiy
