The second version of the design is completed
05/22/2025 at 08:06 • 0 commentsThe new case has fewer parts to print and should be much simpler to assemble. Two main changes made this possible: the protective bumpers on the corners were replaced with a thicker layer of plastic, and the hinges were completely redesigned to be printed together with the case parts.
NetHunter Installation Instruction
05/21/2025 at 15:45 • 0 commentsI've added detailed instructions on how to convert a Google Pixel 3XL smartphone into a network diagnostic and penetration testing device.
Device Redesign – Phase 1
05/21/2025 at 14:25 • 0 commentsI started working on the second version of the device.
Sergiy
