A Raspberry Pi Pico (RP2040)-based (S)RAM / ROM Emulator, and SD Card Interface for vintage Single Board Computers (SBCs) - Revision 2.
About
PicoRAM Ultimate Rev. 2 replaces some (or all) of the (S)RAM or ROM chips of these systems and emulates them in software with a Raspberry Pi Pico (RP2040) microcontroller, slightly overclocked at 250 MHz. PicoRAM is equipped with an SD card to store and load whole memory dumps to and from SD card. These memory dump .RAM files are similar to Intel HEX ASCII format and can be edited easily by hand on the PC or Mac; the utilized FAT file system facilitates data / file exchange.
PicoRAM Heathkit
Currently supported SBCs / host machines are:
The development logs are on Hackaday.
This project is a follow-up to PicoRAM 2090 for the Busch Microtronic Computer SystemPicoRAM 6116 for the Microprofessor MPF-1, and PicoRAM Ultimate Rev. 1. PicoRAM Rev. 1 users, please refer to the Rev. 1 documentation.
In the following, PicoRAM Ultimate refers to the hardware Rev. 2. Please note that this repository contains files for both revisions (rev1rev2). The current firmware Version 2 works with both hardware Rev. 1 and Rev. 2; however, the 4 KB configurations (machine settings) are only supported with Rev. 2 hardware. Some pictures still show the old Rev. 1 - note that the Rev. 1 vs. Rev. 2 differences only matter with regard to the Heathkit ET-3400 machines (and only if PicoRAM is used over the extension header).
Video
This YouTube video (of the Rev. 1 board) shows most currently suported machines (with the exception of the MPF-1P):
YouTube Video
Here is a YouTube Video of the Rev. 2 board, showing both the Heathkit ET-3400 and the ET-3400A.
YouTube Video Rev. 2
Latest News
February 2026
Firmware version 2.1 adds some experimental IO capabilities to PicoRAM for the ET-3400 (not A currently); namely, text and graphics commands.
To use this experimental mode, the 0x1000 to 0x1fff address decoder is required, and the 4x 2112 SRAM chips for 512 Bytes of SRAM memory are retained. In this mode, PicoRAM acts as a ROM emulator for now, so writes to the memory from 0x1000 to 0x1fff are protected, with the exception of address 0x1800 (for now) which acts as a "one byte serial" communication channel from the ET-3400 to PicoRAM for driving the text and graphics display (i.e., for sending IO commands). There are a number of demo programs in this folder. that demonstrate how to utilize the provided text and graphics commands. Note that the machine identifier is 3400IO for this mode; also see the supplied ULTIMATE.INI and the three demo programs which are supplied in .A68 assembly format. Large portions were written by CoPilot, especially for the visual / graphical Towers of Hanoi program HANOIG.RAM.
It should be noted that this mode is still experimental and not fully stable yet; but have a look at this, this, and this YT video to get an impression. Overall, it already works pretty well. In particular, it is necessary to not send IO bytes to address 0x1800 too fast; processing speed also depends on the type of command (unfortunately, PicoRAM can not halt the CPU while it is executing IO commands, as this results in unstable operation). So proper "synchronization by hand" is required in order to get stable operation.
Graphics ET-3400 Hanoi
Graphics ET-3400 Diagonal Net
I also experimented MC-6800 "vibe coding". It's a bit of a mixed bag, but I had best success with Claude Sonnet 4.5, which coded the entire Appleman fractal for me! First a basic b&w version, and then even a dithered version:
Appleman B&W Sonnet
Appleman Dithered Sonnet
At the end, I asked Sonnet to summarize the challenges we faced.
Copilot "Smart" (GPT 4.5?) came up with a version of the Sierpinsiki triangle:
Two YT vidoes:
Overview
PicoRAM Ultimate is powered directly from the host machine; i.e., via the 5V and GND SRAM socket power pins.
To emulate SRAM, PicoRAM needs memory addresses, the 8bit data bus, as well as chip select and write enable signals. These are provided from either the 2112 sockets, the 2114 sockets, the 6116 socket, or the Heathkit expansion header.
The pinouts of these vintage SRAM chips can be found here:
2112 Chip
2114 Chip
6116 Pinout
The specs of these vintage SRAM chips are:
Whereas the primary mode of operation is to simply use ribbon cables connecting PicoRAM to the host machine's SRAM sockets, there is also an extension header option on the PicoRAM PCB that allows to neatly and directly connect PicoRAM to the Heathkit ET-3400(A). In this case, the address and data bus as well as the control signals are not supplied via the SRAM chip sockets, but over the expansion header. A dedicated address decoder is used in this case (GAL16V8).
The address decoder is only utilized for the Heathkit ET-3400(A), and is fully programmable such that PicoRAM's emulated 4 KB of RAM / ROM memory can be mapped into the address space starting at an arbitrary address whose lower five address (A0 to A5) bits are zero - i.e., the 4 KB page can start at any address divisible by 64.
PicoRAM generates a READY/BUSY/HALT signal for the CPU in order to suspend CPU operation while it cannot serve the RAM content (i.e., during file or UI operations). Power (VCC = 5V and GND) is fed in from the sockets and connectors as well (i.e., whatever socket / connector is being used to connect to the host machine supplies power to PicoRAM).
PicoRAM has a convenient OLED-based UI. The hexadecimal ASCII-based file representation of the memory content and FAT32 file system facilitates editing and exchange of memory dumps (programs and data) with a PC or Mac.
PicoRAM also offers an auto-load function - programs can be loaded automatically into the host machine when it powers up (as if these were EPROM-based programs).
A number of jumpers must be set to match the host machine. These jumper settings can be found on the PCB silkscreen as well, although incomplete. It is hence best to refer to this README for the latest jumper settings and supported SBCs.
Features
User Interface
The PicoRAM OLED display (if not turned off) shows the currently loaded RAM file, the machine type, and the current bank number:
Display
On the main screen, the 5 buttons have the functions listed in the legend:
Buttons
During file operation (i.e., when a file is loaded from or saved to SD card), the buttons take on additional functions for file selection, file name creation, to confirm or cancel operations, and so on. It will be obvious (i.e., intuitive) how to use them.
The ULTIMATE.INI Configuration / Initialization File
The 5 UI buttons are read over an analog input on the Pico and mapped to a value within the HEX interval 0x000 - 0xFFF by the Pico's analog-to-digital converter (ADC). The different buttons produce different values in this range. Unfortunately, the analog levels on the Pico are very noisy and also vary from machine to machine, depend on the host machine power supply, etc. These ADC values for the different buttons are mapped to specific UI buttons by means of thresholds; e.g., an ADC value below 0xA00 but higher than 0x800 means the CANCEL button has been pressed, a value within 0x500 to 0x800 corresponds to a push of the OK button, and so and so forth. These threshold intervals are specified in the ULTIMATE.INI file.
Note that proper thresholds are extremely important for a reliable and error-free operation of PicoRAM. Every time a UI button push is detected, the Pico onboard LED will be lit and RAM emulation is paused by pulling down the WAIT/READY/BUSY line of the host system CPU. If PicoRAM should detect false (random, spurious) button presses due to ADC fluctuations and noise, then it is likely that the CANCEL button threshold is set too high. Or, if you are not getting the right function for a button (e.g., the CANCEL button acts as the OK button), then the thresholds must be adjusted to match your machine as well. There are two methods for "tuning" these thresholds, which are described in the next subsection. But first, let us discuss an example ULTIMATE.INI file (here, for the Philips MasterLab):
MASTERLAB
F00
F00
B00
800
500
200
NIMM.RAM
HEXCOUNT.RAM
NUMGUESS.RAM
0
(note that UNIX EOL is required here - a single newline / 0x0A character!).
The file lists, in this order:
So how do we dermine these analog threshold values in case the supplied default init file doesn't work for your machine? Read further.
Determining Analog Button Thresholds
There are two methods:
  1. The PicoRAM firmware contains a Button Tuning function which allows you to acquire the threshold values interactively. You are being asked to push each buttons 5 times, and at the end, you will have the option to write the acquired threshold values to an ADC.INI file on SD card: Tuning
    This file can then be hand-edited and become the basis of a proper ULTIMATE.INI file. This Button Tuning functionality can be invoked by holding down any button during start-up / reset of PicoRAM. Examples of proper init files can be found here.
  2. If you start PicoRAM from an ULTIMATE.INI file that has a 1 entry as its last line, it will start an infinite loop, displaying the analog values as they are being read. You can determine the threshold for each button by inferring a safe upper bound from the values you are observing. For example, in this picture we are observing (noisy) values for the OK button in the 0x800 to 0x8F0 range: Tuning
    A threshold value of 0x900 would hence be a good choice for the OK button threshold in the ULTIMATE.INI file (4th line).
Host Machine-Specific Configuration
PicoRAM supports multiple host machines / SBCs. A machine type-identifier in the first line on the ULTIMATE.INI file determines the machine type.
The following types are supported; each host system is described in more detail below.
These are the machine type-identifiers used from firmware version 2.0 on; more details regarding memory address ranges will be given in the subsequent machine-specific subsections. Please note that older firmware versions (< 2.0) used different identifiers.
For machine identifiers used by older firmware versions (< 2.0), please refer to the old README.
Stock Heathkit ET-3400 without Expansion Header
The Heathkit ET-3400 is a Motorola MC6800-based CPU trainer from ~1976 and can be considered one of the very first CPU trainers.
The stock system came with only 2 2112 SRAM chips (IC14 and IC15), amounting to 256 bytes. Users could upgrade the machine to 512 bytes by plugging in two more 2112 SRAMs into IC16 and IC17. PicoRAM connects to IC14 and IC17 and can emulate 512 bytes of memory in the address range 0x0000 - 0x01ff.
ET-3400 Stock Config
ET-3400 Stock Config 2
Note that this applies to the ET-3400 with original MC6800 CPU with no upgraded crystal, and that you will need a jumper cable from the HALT pin of PicoRAM's J3 header to the ET-3400's HALT breadboard connector, as shown in the above picture.
The machine type string (1st line in the ULTIMATE.INI) is ET3400.
The jumper configuration for this mode is:
JP1JP2JP3JP4JP5JP6JP7JP8JP9A9A10
*XRNR*RRL(R)UU
Where * = don't care, XR = experiment what works best for your machine, but the default should be R, and N means:
Note that the GAL is not required in this configuration. Hence, (R) means that this jumper is only required if the GAL is installed.
Stock Heathkit ET-3400A without Expansion Header
The Heathkit ET-3400A is a Motorola MC6808-based CPU trainer from ~1976, the successor of the ET-3400. It is quite a bit faster than the ET-3400, uses a 6808 instead of the 6800, and 2 2114 SRAM chips instead of the 2 (or 4) 2112 SRAM chips in the ET-3400.
The stock system comes with 2 2114 SRAM chips (U14 and U15), providing 512 Bytes from 0x0000 - 0x01ff. Interestingly, only 512 Bytes are utilized by the ET-3400A instead of the full 1 KB provided by the 2 2114, as the Heathkit designers did not connect the 10th address bit of the CPU (A9) to U14U15 (instead, pin 15 is simply connected to GND for these chips).
ET-3400a Stock Config
ET-3400a Stock Config 2
You will also need a jumper cable from the HALT pin of PicoRAM's J3 header to the ET-3400's HALT breadboard connector, as shown in the above picture.
The machine type string (1st line in the ULTIMATE.INI) is ET3400A.
*XL*RL*RR(R)DD
Where * = don't care, and XL = experiment what works best for your machine, but the default should be L.
Stock Heathkit ET-3400 with Expansion Header
If your ET-3400 has the IO expansion / extension header installed, then PicoRAM Ultimate can upgrade your machine to 2 KBs or 4 KBs ((PicoRAM Rev. 2 only!) of emulated RAM. It then requires an additional address decoder, a GAL16V8; this GAL can map the 2 or 4 KBs (PicoRAM Rev. 2 only) of emulated PicoRAM memory into a user-defined address range specified by the WinCUPL PLD equation in the GAL firmware file. The default range for 2 KBs is 0x0000 - 0x07ff, and 0x0000 - 0x0fff for 4 KBs (PicoRAM Rev. 2 only). As this (intentionally) overlaps with the installed SRAM chips, these SRAM chips need to be pulled in this RAM emulation mode.
Heathkit RAM Extension Header
However, if PicoRAM RAM is mapped into a different region, e.g., starting from address 0x1000 or 0x2000, then PicoRAM memory can coexist in conjunction with the installed SRAM chips. Some users will prefer this, as it maximizes the amount of RAM available to the system, but the machine code demonstratation programs from the Heathkit ET-3400 manual would need to be changed / relocated where applicable (i.e., any absolute addresses used in these programs).
It is also possible to emulate ROM memory with PicoRAM. ROM memory would be protected from programmatic or monitor-based modifications. In ROM emulation mode, the installed monitor (P|EP)ROM (IC12) can be removed and emulated by PicoRAM. This allows you to replace, modify, or extent the built-in monitor program, without having to reprogramm (E)EPROMS. The monitor ROM is 1 KB only and starts at address 0xfc00; PicoRAM can either emulate 2 KBs of ROM starting from address 0xf800, or 4 KBs of ROM (PicoRAM Rev. 2 only), starting from address 0xf000. Note that the machine will not run with RAM, so you will still need the original (SR)RAM chips installed then.
Heathkit ROM Extension Header
Note that this applies to the ET-3400 with original stock MC6800 CPU with no upgraded crystal with an installed (and fully wired-up) expansion header.
PicoRAM plugs onto the expansion header as follows:
ET-3400 Exp.Header 1
In particular, it is assumed that the databus wires have been soldered in (by default, the PCB only accommodates for the address bus and the control signals!), as well as the RE signal:
ET-3400 Exp.Header 3
The databus and RE signal mods are also described in the IO extension box manual.
ET-3400 Exp.Header 4
If you require a custom memory range, you can easily change the RAM_SELECT equation in the GAL PLD file and recompile with WinCUPL, yielding a new [JED file] for the GAL programmer.
For example, we can change the default PicoRAM Rev. 1 decoder to map into the memory region starting at address 0x1000 so that it won't overlap with the installed SRAM chips - all we have to do is change the line
RAM_SELECT = ! A12 & ! A13 & ! A14 & ! A15 ;
to
RAM_SELECT = A12 & ! A13 & ! A14 & ! A15 ;
yielding this PLD file:
PIN  1 = A9 ; PIN  2 = A10 ; PIN  3 = A11 ; PIN  4 = A12 ; PIN  5 = A13 ; PIN  6 = A14 ; PIN  7 = A15 ;
PIN  9  = CS1A8 ; PIN  11 = CS2A8 ;
PIN 19 = WR ; PIN 18 = VMA ;
PIN 15 = RE ;
PIN 12 = SE ;
ACCESS = ! VMA & RAM_SELECT ;
RE = ! ( ACCESS & WR ) ;
SE = ACCESS ;
Note that the PicoRAM Rev. 2 decoder is different from the Rev. 1 decoder, as it allows more fine grained start addresses for the memory pages - whereas the Rev. 1 decoder can only decode based on the address line inputs A9 to A15 (hence, in 2 KB granularity), the Rev. 2 decoder "sees" A6 to A15 (hence, in 128 bytes granularity). Consequently, the RAM_SELECT equation in the Rev. 2 decoder files can have more terms if required.
There is some software for the RAM and ROM configurations; in particular, a 2 KB and 4 KB monitor ROM.. The 2 KB monitor ROM also contains the Towers of Hanoi starting at 0xf800; the monitor itself starts at 0xfc00. The 4 KB monitor ROM (can only be used with PicoRAM Rev. 2) contains the clock at address 0xf000 in addition.
Again, note that the ROM memory is write-protected; hence, you cannot change it with the monitor or programmatically. Use the standard RAM (0x0000 - 0x01ff) for writeable memory in the 3400ROM1 and 3400ROM2 configurations. Of course, as demonstrated with the ROM-included clock and Hanoi programs, it is possible to have your own programs in addition to the monitor. Also note that it is not possible to run the monitor program without (at least some) RAM.
The jumper settings are as follows:
*R*L*LRLLDD
Stock Heathkit ET-3400A with Expansion Header
For the ET-3400A, the same description applies (and see the ET-3400A in the above pictures), but the machine identifiers are different - note that the GAL decoders are identical to the ET-3400 versions as well:
There is some software for the RAM and ROM configurations; in particular, a 2 KB and 4 KB monitor ROM.. The 2 KB monitor ROM also contains the Towers of Hanoi starting at 0xf800; the monitor itself starts at 0xfc00. The 4 KB monitor ROM (can only be used with PicoRAM Rev. 2) contains the clock at address 0xf000 in addition. Note that most programs are identical to the ET-3400 versions; only the clock program is different to accomodate the faster CPU clock.
The same configuration as for the ET-3400 with expansion header applies:
*R*L*LRLLDD
Lab-Volt 6502
The Lab-Volt 6502-based CPU trainer was released by FESTO Didactic in the early 1980s; apparently, the machine was being manufactured at least until 1999 - my accompanying textbook copy is the "16th printing, 1999". The trainer is equipped with 2 2114 SRAM chips (1 KB of RAM):
Lab-Volt
The machine type string (1st line in the ULTIMATE.INI) is LABVOLT.
*R*RNLRR*DD
Where * = don't care and for N:
Moreover, the JP5 setting for 2 KBs
does not work for the Lab-Volt - but might work for a different host machine with 4 2114 chips. Check the schematics.
Lab-Volt 2
A jumper wire must be routed from the HALT pin on J3 to RDY (22) pin on the machine's system bus header (top-left header).
Philips MasterLab MC6400
The Philips MasterLab MC6400 is a INS8070 (SC/MP III)-based CPU trainer released in ~1984. Despite the Philips label, the machine was only released in Germany, and likely developed in my birth town, Hamburg / Germany. More infos can be found here. It is equipped with 2 2114 SRAM chips (1 KB of RAM):
MasterLab
You will have to modify your MC6400 and put in sockets to accommodate PicoRAM as follows. The PCB is of very good quality, and with a little bit of soldering skills you will have no issues accomplishing this:
MasterLab Mod 1
MasterLab Mod 2
The machine type string (1st line in the ULTIMATE.INI) is `MASTERLAB``.
*R*RNLRR*DD
Where * = don't care and for N - emulate
does not work for the MasterLab - but might work for a different host machine with 4 2114 chips. Check the schematics.
Note that a jumper wire is required that connects the HALT pin of the J3 header to the MasterLab's Master Reset as follows - this is the first top-most connector socket that is not occupied by a wire bridge:
MasterLab Mod 2
It can be seen more clearly in this pinout diagram:
MasterLab Connector
Multitech Microprofessor MPF-1
The company Multitech (nowadays: Acer) released a series of Z80-based trainers as early as 1981 (MPF-1); later models included a Palo Alto TinyBASIC EPROM (MPF-1B), and the much more powerful and capable MPF-1P (One Plus) that featured an alphanumeric keyboard and VFD, had a symbolic 2pass assembler with line editor, a full floating point BASIC, and Forth! More info about these fascinating machines can be found here.
The machine type string (1st line in the ULTIMATE.INI) is MPF. PicoRAM emulates one 6116 chip and supplies 2 KBs of SRAM.
Ultimate MPF
Ultimate MPG 2
The jumper settings are:
RL*R*LLL*DD
On the MPF-1(B), PicoRAM should be plugged into the U8 6116 socket. For the MPF-1P, the U5 6116 socket should be used.
For U8 on the MPF-1(B), the 2 KBs of RAM usually appear in the address range 0x1800 - 0x1FFF. On the MPF-1P, U6 is mapped to 0xf800 - 0xFFFF.
The HALT pin of the J3 header needs to be connected to pin 37 on the MPF's (1, 1B, 1P) primary (top-left) extension header via a jumper wire. Double check JP1 as well; for the Microprofessor, it needs to be set to R (for CE, pin 18).
I also recommend to add an additional decoupling capacitor (104, 0.1 uF / 100 nF) between GND and VCC of the 6116 socket to help with noise:
MPF Capacitor
If you encounter stability problems, try removing the 10k resistor array completely.
MPF Resistor
Also have a look at the predecessor project, PicoRAM 6116.
Host Machine-Specific Software and Example ULTIMATE.INI Initialization Files
PicoRAM uses a FAT32-formatted (max 32 GB) Micro SD Card.
To get started, you can simply copy the sub-directory for the intended host machine from the software/ directory.
Theory of Operation
The Raspberry Pi Pico emulates the SRAM of the host machine and is overclocked to 250 MHz to make this possible; this is completely in the safe range and does not affect the longevity of the RP2040 in any negative way.
Due to a lack of GPIOs on the Pico, two 74LS373 (or 74F373) transparent octal latches are used to multiplex the (max) 12-bit address bus. The (up to) 12-bit address is read in two batches of 6 bits, using the SEL1 and SEL2 signals from the Pico to OE (Output Enable) the first resp. second latch. The latches are merely used for their tri-state capabilities.
Unlike my previous design, PicoRAM 2090, this design does not utilize any voltage level converters. It turns out that the Pico (RP2040) is really pretty much 5V-tolerant; also see this article from Hackaday and the Hackaday coverage of PicoRAM 2090.
Development 1 Development 2 Development 3 Development 4
More details about the making of the project, and technical notes / development logs can be found on the PicoRAM 6116 Hackaday project page and the PicoRAM Ultimate Hackaday project page.
The Board
Schematics
Schematics
Here is a PDF of the schematics.
Printed Circuit Board (PCB)
The current version is Rev. 2, January 2026.
PCB
There is also a Bill of Material (BOM).
Note that the resistor array should be 10K (code: 103). The 2112, 2114, 6116 chips are only sockets, obviously (so you don't actually need to purchase any SRAM chips - PicoRAM emulates them).
Gerbers
Gerbers
See here.
Firmware Image
The current version is 2.0, January 27th 2026. The .uf2 image can be found here.
Firmware Sources
See here.
Acknowledgements
