Keeping the original SRAM chips installed...
A project log for PicoRAM Ultimate Rev. 2
SRAM Emulator and SD Card Interface for Vintage Single Board Computers (such as the Heathkit ET-3400, Lab-Volt 6502, and Microprofessor)
michael-wesselMichael Wessel 01/19/2026 at 17:270 Comments
... is indeed possible: simply change the address decoder. For example, by changing the GAL equation for the decoder from
RAM_SELECT = !A11 & !A12 & !A13 & !A14 & !A15 ;
to
RAM_SELECT = !A11 & !A12 & !A13 & !A14 & A15 ;
the emulated 2 KBs of RAM will appear in the 0x8000 - 0x87ff address range instead of the default range from 0x0000 - 0x07ff.
This hence gives you 2.5 KBs, adding 512 bytes from the existing SRAM chips to PicoRAM's 2 KBs. Note that the 2 2114 chips are on board here, and don't conflict with PicoRAM. It is probably even possible to pull the ROM chip (0xfc00 - 0xffff) and hence change the monitor program if needed (i.e., by putting a custom "emulated ROM" in there that can conveniently be updated and developed without having to burn (E)EPROMs all the time):
