Welcome!
If you're looking for a way to display all your social media followers' information on one device, this project is for you! The project uses Awtrix software (open-source), and basically, it is a blank display, and you can display ANYTHING you want there (not only social media information).
This is my first project on Hackaday, so if it feels like this post is all over the place, it's because I'm still learning :)
This project uses an open-source project called Awtrix3 - link
I wrote step-by-step instructions for the project, and all the 3d printed parts needed are available on my Printables.
The Display has 3 Touch sensors, and a Temp/Humidity sensor. You can seed all the information Via MQTT to HomeAssistant and control it via HA.
Printed parts needed:
1x Body left
1x Body Right
1x Diffuser Left
1x Diffuser Right
1x Diffuser Connector
4x LED Support
Electronics:
8*32 WS2812B Matrix Display -
Temperature & Humidity Sensor
TTP223 Capacitive Touch Switch
On/Off Switch
Power Supply
Need to choose from 2 options:
PCB - Fully assembled PCB that will make the project much easier (and will also help and support us to make more projects like that) -
OR
ESP32 version - you will have to wire everything yourself and hot glue the power connector and the ESP to the body of the display.
Hardware:
M3 Thread Inserts (x23)
M3X8 Screws (x11)
M3X5 Screws (x16)
Step-by-Step Video (Body + Software): the easy way
The Printing Pilot
Arnov Sharma
c3dprk
