Hypno-Goggles
A homemade device for "brainwave entrainment"
Brainwave entrainment is the idea of using audio visual stimuli to produce a specific state of mind, and target specific "brainwave bands". I have no idea how much of that is bullshit, but I have found such devices entertaining and relaxing when I've used them, typically at tourist destinations.
However, while the hardware is extremely simple, setups from vendors like MindPlace can cost several hundred dollars, which is excessive, and also the hardware usually looks glossy and consumerized. Yuck.
I therefore decided to cobble some together out of parts I already own.
Steve Hernandez wrote 05/28/2025 at 21:35 • point
I built a similar device that also uses binaural beats and a sleep mask with leds. What frequencies do you use?
