Full-stack IoT project - LabJack U3-HV.
Full-stack IoT project built with React, Flask
Public Chat
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
LabJack Sensor Dashboard - a full-stack IoT project built with React, Flask, and Socket.IO to stream and visualize real-time sensor data from a LabJack U3-HV.
Key Features:
Real-time updates every second via Socket.IO
Historical and live data analysis (min, max, range) with Chart.js
Styled with Tailwind CSS for a modern dark-mode interface
Data stored in SQLite, served via a Flask REST API
Fully responsive design, works on both mobile and desktop
Sensors connected:
Device temperature
Air temperature
Light intensity (via voltage divider)
Switch between Live data and Collected Analysis using dynamic tabs. All sensor values are updated in real-time and visualized using Line, Bar, Pie, and Radar charts.
This project was built as an educational tool to explore full-stack data flow - from hardware to frontend UI. Next steps: enhance analytics and add export/report features. Possibly deploy online
https://www.linkedin.com/embed/feed/update/urn:li:ugcPost:7331135070826631168?compa
