Hardware:
Hardware is set up in 4 blocks:
USB, Controller, variable DCDC and output.
The main controller is an AVR126DA32 and a MCP2221A USB to serial device.
The SPI output is buffered via 4 level shifters.
This allows the output to consist of multiple voltage levels.
The output voltage is controlled via a variable voltage supply and a digital potentiometer
The possible output voltages are: 5, 3.3, 2.5, 1.8 and 1.2V
Connectors from to view:
Software:
The software is controlled by simple clear text commands. these lets you control the voltage level and change SPI modes / clock.
Commands are for example:
VE - voltage enable
V5- voltage to 5V
SThh,hh,hh - SPI transmit followed by hex values
-> command_list .h
Hulk
Bert Jerred
Stefan Wagner
