Xiaomi Mi smart sensor Hack
This project is a hack of a Xiaomi Mi smart sensor in aim to develop your proper code with a zigbee protocol
The goal of this project is to use a great lowprice hardware to reuse with your proper zigbee protocol.
Thank to this project, you can make your proper coordinator with a 6$ sensor. With a USB/Serial TTL converter, you have all you need for a Zigbee/Serial gateway.
When it's done, you can reprogram all of your Xiaomi sensors to be avalaible with your gateway. This hack allow you to get a lowprice domotic system
In this project you will see :
- How to spot the programing port of Xiaomi Sensor
- How to create a UART Programer
- How to install and use programing software
- How to get original Network Key and decode payload
  • 1 × USB / Serial TTL FTDI USB / Serial TTL converter
  • 2 × Push button
  • 2 × 10Kohm resistor
View all instructions
