Introduction
In today’s world, automation and hygiene have become essential, especially in public places like hospitals, malls, and offices. This project presents an Arduino-based Mist Maker and Hand Dryer system with a 16×2 LCD Display, designed to improve user convenience and maintain hygiene by minimizing physical contact.
For Full Project:
https://electronicsworkshops.com/2025/05/18/arduino-based-mist-maker-and-hand-dryer/
The system uses an ultrasonic sensor to detect the presence of a hand. Upon detection, it automatically activates both a mist maker, which adds moisture to the air, and a DC fan, which acts as a hand dryer. The status of the system is displayed on a 16×2 LCD screen, making the operation user-friendly and easy to monitor.
This project combines basic electronic components with Arduino programming to create a simple, low-cost, and effective automated solution. It is ideal for learning automation, sensor integration, and LCD interfacing, and can be extended for various hygiene-based applications in real-world environments.
Bill Of Materials
| SN | COMPONENTS NAME | QUANTITY | ALIEXPRESS LINK | AMAZON LINK |
| 1 | Arduino UNO | 1 | ALI-EXPRESS BUY | AMAZON BUY |
| 3 | Ultrasonic Sensor | 1 | ALI-EXPRESS BUY | AMAZON BUY |
| 4 | LCD Display 16*2 | 1 | ALI-EXPRESS BUY | AMAZON BUY |
| 5 | Mist maker | 1 | ALI-EXPRESS BUY | AMAZON BUY |
| 6 | Connecting Wires | Some | ALI-EXPRESS BUY | AMAZON BUY |
| 7 | Bread Board | 1 | ALI-EXPRESS BUY | AMAZON BUY |
| 8 | Relay Module | 1 | ALI-EXPRESS BUY | AMAZON BUY |
Working Principle of Arduino-based Mist Maker and Hand Dryer
The Arduino-based Mist Maker and Hand Dryer operates using a sequence of sensor-based actions, controlled through programmed logic. The following outlines the working principle:
- System Initialization:
The system starts and enters an idle state, waiting for user interaction. A message is displayed prompting the user to place their hand near the sensor. - Hand Detection:
An infrared (IR) proximity sensor continuously monitors for the presence of a hand. Once a hand is detected within a certain range, the system transitions to the sanitization phase. - Mist and UVC Activation:
Upon hand detection, a timer is initiated. Simultaneously, the mist maker and UVC light are activated. The mist acts as a sanitizer, while the UVC light provides additional sterilization by eliminating microorganisms on the hands. - Timer Control:
The system continues the misting and UVC sterilization for a predetermined time interval, ensuring effective sanitization. If the hand is removed prematurely, the system resets. - Fan Activation (Hand Dryer):
After the timer expires, the mist and UVC light are turned off, and the fan is activated. The fan blows air to dry the sanitized hands, completing the hygiene process. - System Reset:
Once the hand-drying process is complete, the system returns to the initial state, ready for the next user interaction
For Full Project:
DIY Prototype
Mist Maker and Hand Dryer using arduino
Order Directly from PCB WAY
I have already uploaded all these required manufacturing files in PCBWAY website. You can easily go to the below link and place you order, and get your Own Home Automation PCB manufactured from one of the best pcb manufacturer PCBWAY
Youtube Link
Conclusion
The Arduino-based Mist Maker and Hand Dryer system is an automated, contactless hygiene solution that integrates ultrasonic sensing, mist spraying, UVC disinfection, and drying mechanisms. Controlled by an Arduino UNO, the system detects the presence of a hand using an ultrasonic sensor, activates a mist maker and UVC LED for sanitization, and then operates a fan for drying—ensuring efficient and touch-free hand cleaning. This project combines automation, safety, and hygiene, making it ideal...
Himanshu Dada
Home Awesomation
Kutluhan Aktar
