ATLAS v1.9 - GPS Integration & Location Intelligence
Rebranding to ATLAS: I've been calling this project the "AI Field Analyzer" but let's be honest - ATLAS (Advanced Tactical Location Aware Sensor) sounds way cooler and actually describes what it does. Plus, like the mythological Atlas holding up the world, this thing carries all your environmental awareness on its shoulders.
Well, I got tired of my ATLAS not knowing where it was, so I taught it some location awareness using clever sensor fusion. Next upgrade will be adding a SparkFun GPS Breakout - NEO-M9N (parts on order), but for now it's pretty smart at figuring out if you're in a cave, your car, or standing in a field using what it already has.
Key v1.9 Upgrades:
- Location Detection: Uses light levels and sensor patterns to determine environment (GPS upgrade coming soon)
- Enhanced Weather Prediction: Storm probability calculations with arrival timing (because "might rain" isn't useful, "70% chance in 2 hours" is)
- Location-Aware Sensor Polling: Automatically adjusts update rates based on detected environment
- 8-Screen Display System: Added dedicated weather and location screens
- Memory Optimization: Fixed the display hanging issues and scrolling problems
- Enhanced Error Handling: Because field equipment that crashes is useless equipment
Location Intelligence - The Cool Part:
The ATLAS now automatically detects whether you're OUTDOOR (bright light = 8+ simulated satellites), INDOOR (moderate light = 2 satellites), VEHICLE (based on sensor patterns), or CAVE (dark = 0 satellites). Here's where it gets smart - when outdoors, it focuses on weather sensors for storm prediction. Move indoors? Shifts focus to air quality monitoring. The system adapts automatically, giving you exactly the environmental intelligence you need for your current situation.
The Fog Detection Discovery: Had a cool "aha!" moment when the device was screaming about fog after a heavy rain - high humidity, low light, all the classic fog indicators. But I was standing outside and could see perfectly fine. Turns out the lux sensor was the key - real fog blocks light significantly, but post-rain high humidity without the light reduction isn't actually fog. Now the system uses sensor fusion between humidity, temperature, and actual light levels to distinguish between "fog conditions" and "actual fog." Sometimes the best discoveries happen when your device disagrees with your assumptions and you realize it's teaching you something new about the environment.
The result? Intelligent power management and relevant data prioritization without manually switching modes. Once I get the real GPS module integrated, this will be even more accurate, but the current sensor-fusion approach works surprisingly well.
Plus, the weather prediction system provides localized forecasting based on your detected environment. It's telling you "STORM INCOMING: 75% probability in 1-3 hours" based on multi-sensor atmospheric analysis.
Code Architecture: Split the codebase into modular components - sensor_manager.py handles all the hardware interfacing and data collection, display_manager.py manages the 8-screen UI and user interface, weather_manager.py handles the storm prediction algorithms, and main.py coordinates everything and runs the main operational loop. Clean separation makes the code way easier to maintain and debug when you're iterating this fast.
Code is on GitHub as always - if you want to build your own ATLAS, everything's there. Still spending every penny on prototypes, but hey, the future isn't coming fast enough, so I'm building it myself.
Apollo Timbers
