Thermal Imager with Medical Mode Demo
A project log for ATLAS
Built the tricorder I actually wanted in the field: one that warns, not just measures.
apollo-timbersApollo Timbers 07/23/2025 at 14:160 Comments
Ultra-Fast Thermal Imager: 12.5Hz C++ Performance with Medical Detection
Demo video of my thermal imaging module achieving 8Hz sensor/12.5Hz display refresh rates (fall short with all the math in the background however very quick) - a complete rewrite from CircuitPython to C++. While CircuitPython was too slow for the frame rates I needed, the main driver for C++ was integration with my Talky voice interface system, which is C++ only.
Technical Achievements:
Medical Mode Intelligence: The system starts in standard thermal imaging, then auto-switches to medical mode after 30 seconds. In medical mode, it performs human skin detection and applies a 1.5°C offset to estimate core body temperature. This enables real-time classification of hypothermia, normal temperature, and various fever levels (low, moderate, high, critical).
C++ Integration Benefits: The C++ rewrite solved both the performance bottleneck and enables seamless integration with the Talky voice system. The low-level optimizations deliver the fluid performance you see in the demo.
This thermal module will be a key component in the complete Tricorder build, providing both standard imaging and medical-grade temperature screening.
