Version 1 Complete
A project log for Underwater Drone Submarine Torpedo
DIY project to create an autonomous drone submarine, capable of basic navigation
sam-johnsonSam Johnson 06/10/2025 at 21:150 Comments
Version 1 of the drone submarine is complete! It still lacks many of the capabilities I hope to add to it, but I have reached a significant milestone. The sub:
Capabilities I hope to add in version 2:
In order to fit another battery pack in the sub, I've made adjustments to the ballast system that will allow it to use only 1 gear instead of 2, and I shielded the piston from the battery pack with a tube-like structure. I am modifying the battery packs to stay in place so they can't jumble around as much.
I have a new PCB on its way from China right now that will allow me to add a GPS and compass module. I have yet to perform a sanity test on the pressure sensor; that will need to happen as well.
