With the boost in torque and power, and thanks to some wet, slippery and soft ground, we hit a new problem: loss of traction.
Eventually running shoes with spikes inspired me. My latest attempt swapped TPU for PLA and used spike-like lugs. These actually worked... for a little while.
Unfortunately, the PLA hub, secured with a set screw on the motor shaft flat, failed under load. The keyway distorted and then melted/softened and then the wheels fell off!
To solve this, I found a proper metal hub adapter from the GoBilda range. These provide a much stronger interface between motor and wheel and allow easy, secure mounting going forward.
Now, just have to wait until the rain stops for further testing.
Mark Makies
