Supplies
Electronics Components
  1. IC1:BQ24075 (LiPo Charger)
  2. IC2:PAM2401 (Boost Converter)
  3. L1: 2.2µH Inductor (2A saturation current)
  4. D1: Schottky Diode (SS34)
  5. USB-C Connector (SMD, 16-pin)
  6. JST 2.0mm Connectors (Battery + Output)
  7. LEDs (Power/Charge Status)
Tools & Materials
  1. PCB Fabrication:JLCPCB (Purple solder mask!)
  2. Soldering:
    1. Stencil
    2. Solder Paste (Low-Temp)
    3. Hotplate
    4. Precision Tweezers
  3. Debugging:
    1. Oscilloscope
    2. Multimeter
    3. Microscope
  4. Design Software: Altium Designer
Circuit Design
The Two Key ICs
BQ24075 Charger IC
Why? Handles all lithium battery charging logic
Key Feature: Built-in thermal regulation (no cooked batteries!)
Setup: Identical to my previous project (USB-C in, 500mA default)
PAM2401 Boost Converter
Why? Converts low battery voltage 0.9V–4.2V battery voltage to a stable 5V/500mA output
Key Specs: 1MHz switching, needs 2.2µH inductor (I used a 2A-rated one)
Gotcha: LX pin requires careful PCB routing
Circuit schematic showing charger and booster ICs
Schematic Tips
  1. Isolate power paths! My mistake: Accidentally connecting charger/booster outputs (more in Step 4).
  2. Add reverse protection (Schottky diode on USB input).
Critical Design Choices
  1. Size: 24mm × 34mm (fits behind a battery)
  2. Ground Plane: Full copper pour under power components
  3. Component Placement:Inductor <5mm from PAM2401 (reduces noise)
  4. USB-C port on left edge for easy access
🛠️ Design Tools Used
  1. Schematic CaptureAltium Designer
  2. Component Sourcing: Selected JLCPCB-compatible parts for easy assembly
⚠️ Pro Tip: Run a Design Rule Check (DRC) before ordering PCBs!
📁 Design Files:
  1. Full Schematic PDF
  2. Altium 365 Project
Assembly
After getting the Circuit very well designed, I generated its related GERBER files and uploaded them to JLCPCB website to order these Purple color PCBs.
Purple PCBs from JLCPCB
Soldering Steps
🛠️ Tools Needed:
  1. Stencil + solder paste (I used Chip Quik TS391LT)
  2. Hotplate (or reflow oven)
  3. Precision tweezers (for 0402 components)
1. Apply solder paste using a stencil.
Applying solder paste with stencil
2. Place components with the aid of tweezers in this order:
  1. Start with the small parts (Capacitors, resistors)
  2. PAM2401/BQ24075 ICs
  3. Inductor and passives
  4. USB-C connector (check alignment!)
Placing components with tweezers
3. Reflow on a hotplate (220°C for 90 sec).
Reflowing PCB on hotplate
🔍 Check: Inspect joints under a microscope, look for bridged pins or cold solder.
Debugging the "Voltage War"
After getting the circuit very well assembled, I moved to do some tests targeting a 5V output voltage from a Lithium 3.7V battery so the needed result should be a boosted stable voltage coming from this circuit:
Assembled circuit board ready for testing
❌The Problem
  1. Booster output stuck at 3V instead of 5V
  2. Inductor overheating
  3. LX pin showing glitchy pulses (scope capture below)
Oscilloscope showing erratic LX pulses
Symptoms & Fixes
Inductor overheating ---> Output short ---> Check LX pin with scope
3V output (not 5V) ---> Booster disabled ---> Verify EN pin voltage
Erratic LX pulses Feedback ---> loop broken ---> Measure FB pin (0.6V?)
  1. Root Cause:
  2. My schematic accidentally connected the charger and booster outputs!
✔️The Fix
  1. Cut the conflicting trace between ICs.
  2. Verified clean 5V output afterward.
  3. Check the output Pulses signal from the booster LX pin to the inductor
Fixed LX pin signal showing clean square wave
I then updated the Design files and fixed the GERBER as well :)
Performance Metrics
  1. Efficiency: 92% at 500mA load
  2. Output Stability: ±50mV ripple
  3. Charging Current: 500mA (adjustable via resistor)
✅ Success! Now it charges batteries and delivers 5V reliably.
final result
