Hackaday.io Hackaday.io
Sign up Log in
Makeblock Robot Tank Enhanced
As the nor'easter rages, I made a enhanced tank to trail though the snow and heavy winds.
ricardo-ferroRicardo Ferro
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
341 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 1
    • View all
  • Instructions 0
  • Discussion 0
View Gallery
562
0
341
2
Team (1)
  • ricardo-ferroRicardo Ferro
Join this project's team
completed project
hardware
TANK drill makeblock arduino uno
This project was created on 03/14/2017 and last updated 9 years ago.
Description
Modified MakeBlock Tank with a switched out stock motors,stock Makeblock microcontroller for a 313 RPM Planetary Gear Motor, Arduino Uno ,Seeduino Motor Shield V2.0,bluetooth HC-05 module for a fast easy setup.(drilling required 1/4 drillbit)
Project Logs
Collapse
  • Captains Log #1 Selling This On Ebay!
    Ricardo Ferro • 06/07/2017 at 17:30 • 0 comments
    I selling this Fully Assembled Bluetooth Controlled Tank on eBay (I barely used it)
    DirectionBluetooth Command
    Forward1
    Left2
    Right4
    Backward
    ______
    Stop
    3
    _________________________________________________________
    5
    http://www.ebay.com/itm/192210649522
View project log
Log In/Sign up to comment
Sign up with Github
OR
I want to operate a Brushless DC motor on a scroll vacuum pump to control a sample cell under vacuum with an Arduino.
Project Owner Contributor
Arduino w/ BLDCSHIELD to run Scroll Vacuum pump
estebanEsteban
"Whosoever balances this hammer, if they be worthy, shall possess the power of Thor..."
Enchanted Thor Hammer
vipin-mVipin M
The MX1508 motor driver module is a small, low-cost module used to control DC motors and small stepper motors. It is based on the MX1508 IC,
electronicsworkshopselectronicsworkshops
I will give you the complete schematics, codes and complete layout of all the boards used in this Arduino RC robot to make one yourself.
Arduino-Remote-Controller-using-HC12-Wireless
mrinnovativeMrinnovative
Going up?
© 2026 Hackaday
Yes, delete it Cancel
You are about to report the project "Makeblock Robot Tank Enhanced", please tell us the reason.
Send message
Remove Member
