Apply soap around letters
Smear silicone. Adding masking tape helps
Wait for silicone to cure
Remove silicone with your fingers. Wash in warm water
Install button and board
Use heat inserts and m3 screws to attach the bottom cover. Or simply glue it
Push something into git !
