Circuit Schematic & PCB
A project log for DIY PWM-Controlled IKEA TILLREDA Induction Cooktop
Modifying a 2kW induction cooktop for precise control via PWM, enabling integration into an automated beer mashing and cooking system.
fieldmanFieldman 06/21/2025 at 20:160 Comments
See the included schematic and PCB layout.
The circuit is intentionally simple, using components I already had on hand. The most critical design requirement was to maintain SELV (Safety Extra-Low Voltage) isolation between the opto-coupler input and the rest of the PCB, as well as the cooktop’s internal electronics.
The PCB was home-etched, which is the fastest and easiest method for a simple board like this. It features a single routed top layer and a solid ground plane on the bottom, which simplifies etching.
To protect against moisture or condensation, the board is finished with a conformal coating.
A 3.5mm jack is used as the input for the external PWM control signal.
For secure installation inside the cooktop, the PCB is mounted using a custom 3D-printed base.
