Zero Effort Coffee Timer
Its glued together
jonJon
A simple two stage visual timer made out of only three parts.
Coffee Timer Body.stl
Standard Tesselated Geometry - 110.34 kB - 06/26/2025 at 15:45
Download
CoffeeTimer.ino
100% AI Generated, just give it your WiFi password.
ino - 14.57 kB - 06/26/2025 at 15:45
Download
Coffee Timer Dots.stl
These are meant to be printed in situ but if you don't have a MMU/AMS they could probably be scaled a few percent smaller and press fit
Standard Tesselated Geometry - 45.98 kB - 06/26/2025 at 15:45
Download
Coffee Timer.zip
Multi color obj
x-zip-compressed - 24.78 kB - 06/26/2025 at 15:45
Download
Coffee Timer Cover.stl
Fill the whole thing with glue and slap this on top to hide your sins
Standard Tesselated Geometry - 684.00 bytes - 06/26/2025 at 15:45
Download
  • 1 × Wemos D1
  • 1 × IR Infrared Obstacle Avoidance Sensor Module Or a button
  • 1 × WS2812B LED Strip About 5 pixels
  • 1
    Solve simple problems with simple solutions
    Decide that a coffee timer would be useful. Just an LED that turns on for a minute or two and then turns off. That sounds like something I could use that 555 that's been in my drawer for years for, so simple. One shot 555 timer. Easy.
  • 2
    Build 555 timer circuit
    Spend an hour getting all the jumpers and breadboards and components out and make sure all 20+ connections are correct.
    Perfect.
  • 3
    Throw it all away
    It only works half the time and triggers when it shouldn't the other half. Swap component values to see if anything improves. Calmly disassemble everything and return components to their respective bins and certainly not dump everything into the 'to be sorted' bin.
View all 6 instructions
