Next obstacle: grass. Total fail—the plastic differential shredded both pinion and ring gears.
But failure led to innovation: I swapped to a multi-stage planetary gear reduction and temporarily locked the rear wheels together. It worked, though imperfectly.
Eugene Tkachenko
