🎯 Why This Project?
Most electronics kits focus on plug-and-play success. But real engineering is about failures, scope traces, wrong voltages, and unexpected behaviors. Bug in Circuit embraces this reality and makes it a core part of the learning journey.
🔧 Learn to use a multimeter like a pro
🔌 Trace circuit paths and understand real-world PCB design
🧪 Discover common beginner mistakes—from cold solder joints to misrouted signals
☁️ Integrate with Arduino IoT Cloud, Google Assistant, or Alexa
🧠 Think like a hardware debugger, not just a coder
🔍 What's the Bug?
We won’t tell you 😉
That’s the point. You’ll have to find it yourself using your tools and logic. Could be:
A missing pull-up, A broken track, A swapped pin, An unpowered relay, A logic inversion
Each board is a new challenge.
🧑🏫 Who’s It For?
👩🎓 Students – Learn
