Established the fundamental ROS 2 communication interfaces that form the backbone of ChessMate’s distributed intelligence system. This work focused on creating standardized message definitions, service interfaces, and action specifications that enable seamless communication between all system components.
Custom Message Package Creation
Package: chessmate_msgs
Successfully created and configured the core message package with proper ROS 2 structure:
- Package configuration with appropriate dependencies
- Build system integration with
rosidl_default_generators - Proper dependency management for
geometry_msgs,sensor_msgs, andstd_msgs
Chess Game Message Definitions
Core Chess Messages
// ChessMove.msg - Standardized chess move representation string from_square # e.g., "e2" string to_square # e.g., "e4" string piece_type # "pawn", "rook", "knight", "bishop", "queen", "king" string move_type # "normal", "castle", "en_passant", "promotion" string promotion_piece # For pawn promotion (optional, empty if not promotion) bool is_capture # True if move captures opponent piece float32 confidence # AI confidence in move (0.0-1.0) int64 timestamp # Move timestamp (nanoseconds)
// ChessPiece.msg - Individual piece representation string color # "white", "black", or "empty" string type # "pawn", "rook", "knight", "bishop", "queen", "king", or "none" bool has_moved # For castling/en passant logic int32 square_id # 0-63 representing a1-h8 (optional, for board representation)
// BoardState.msg - Complete chess board representation ChessPiece[64] squares # Array representing 8x8 board (a1=0, b1=1, ..., h8=63) string active_color # "white" or "black" string castling_rights # "KQkq" format string en_passant_target # Square name or "-" if no en passant possible int32 halfmove_clock # Moves since last capture/pawn move (for 50-move rule) int32 fullmove_number # Game move counter string fen_string # Full FEN representation for validation int64 timestamp # Board state timestamp
Robot Control Message Definitions
Hardware Interface Messages
// GripperCommand.msg - End effector control string action # "open", "close", "grip_piece", "release_piece" float32 force_limit # Maximum grip force (Newtons, 0.0 = no limit) float32 timeout # Command timeout (seconds) bool gentle_mode # True for delicate piece handling
// RobotStatus.msg - System health monitoring string state # "idle", "moving", "gripping", "error", "calibrating" geometry_msgs/Pose current_pose sensor_msgs/JointState joint_states string[] active_warnings string[] error_messages float32 battery_voltage # For future wireless operation (0.0 if N/A) bool gripper_has_piece # True if gripper is holding a piece int64 timestamp # Status timestamp
Service Interface Definitions
Kinematics Services
// ForwardKinematics.srv - Joint angles to Cartesian position # Request float64[3] joint_angles # [theta1, theta2, z] in radians/meters --- # Response geometry_msgs/Pose end_effector_pose bool success string message
// InverseKinematics.srv - Cartesian position to joint angles # Request geometry_msgs/Pose target_pose float64[3] seed_angles # Initial guess for solver (optional) --- # Response float64[3] joint_angles # Solution angles [theta1, theta2, z] bool success string message float64 solution_quality # Metric for solution optimality (0.0-1.0)
// ChessSquareKinematics.srv - Chess-specific positioning # Request string square_name # "a1" through "h8" float32 piece_height # Height above board (mm) string approach_direction # "top", "side" for collision avoidance --- # Response geometry_msgs/Pose target_pose float64[3] joint_angles bool success string message
Action Interface Definition
Complex Multi-Step Operations
// ExecuteChessMove.action - Complete move execution # Goal ChessMove move bool animate_move # Show intermediate positions float32 move_speed # Speed multiplier (0.1-2.0, 1.0 = normal) --- # Result bool success string completion_message float32 execution_time ChessMove executed_move # Echo of the move that was executed --- # Feedback string current_phase # "approaching", "gripping", "lifting", "moving", "placing", "complete" float32 progress_percent # 0.0-100.0 geometry_msgs/Pose current_pose string status_message # Human-readable status
Build System Integration
Package Configuration
- Proper
package.xmlwith interface dependencies CMakeLists.txtconfigured for message generation- Integration with
rosidl_default_generators - Dependency management for standard ROS 2 message types
Build Verification
# Successfully generated all interfaces: chessmate_msgs/msg/BoardState chessmate_msgs/msg/ChessMove chessmate_msgs/msg/ChessPiece chessmate_msgs/msg/GripperCommand chessmate_msgs/msg/RobotStatus chessmate_msgs/srv/ChessSquareKinematics chessmate_msgs/srv/ForwardKinematics chessmate_msgs/srv/InverseKinematics chessmate_msgs/action/ExecuteChessMove
Interface Testing & Validation
Message Structure Verification
- ✅ All message types properly defined and accessible
- ✅ Service request/response structures validated
- ✅ Action goal/result/feedback interfaces confirmed
- ✅ Dependency resolution for geometry_msgs integration
- ✅ Build system generates interfaces without errors
Architecture Benefits
- Type Safety: Strong typing prevents communication errors
- Standardization: Consistent interfaces across all nodes
- Chess-Specific: Optimized for chess domain requirements
- Hardware Abstraction: Clean separation between logic and hardware
- Extensibility: Easy to add new message types as system evolves
Completion Status
✅ Completed
- Message package creation and configuration
- Chess game message definitions (ChessMove, ChessPiece, BoardState)
- Robot control messages (GripperCommand, RobotStatus)
- Kinematics service interfaces (Forward/Inverse/ChessSquare)
- Action interface for complex move execution
- Build system integration and testing
- Interface validation and verification
Vipin M
