Assembled but not working, then debugged.
Adobe Portable Document Format - 66.52 kB - 06/30/2025 at 01:25
Okay, it doesn't work. Now what?
One can start with a visual check.
Well it looks like it was made correctly.
The Ground wire pad has come off the board, that will need fixing.
After that a multimeter is an essential basic tool for any electronics hobbyist.
First step, find the circuit diagram.
Find the picture of the board with the component identifiers
Common faults include:
I have the good fortune to have a working version to use as a reference.
I took a picture of the PCB tracks.
Current consumption: 83.8 nanoamps, so it is not shorting anything to ground.
Observation: There is no activity at all. The fault is causing BOTH transistors in BOTH flip-flops to be in the off state.
9 volts on one resistor but not three others - found a PCB track broken.
Fixed, and one flip-flop works.
Heated a few dry-looking joints on the other flip-flop, and now it works.
View project log
Kelvin Brammer
zacnotes
Josh Kittle
Ian Dunn
Yes, delete it Cancel
You are about to report the project "Velleman Christmas Tree", please tell us the reason.
