The Long and Winding Road
A project log for Teapot in The Garden
Imagine a teapot filled with an infinite number of fortune cookies. If it usually gave good advice, would you do as you are told?
glgormanglgorman 07/06/2025 at 15:200 Comments
"The Long and Winding Road" is actually the title of yet another Beatles song, and a great one at that.  Yet, I didn't wake up today thinking that I was going to post another log entry on this project, with that song title or any other song title in mind.  Not at all.  But I did decide to look at the x86 disassembly for the code that calculates the current position of the sun in the sky, so as to try to get an idea as to what sort of other platforms it might work on.  Custom 6502? 328P?  Z80 dream machine.  8080A on a genuine Altair?  Or just another Arduino or Propeller project?
void solar_elements::compute_local_aspect()
004C2EC0  push        ebp
004C2EC1  mov         ebp,esp
004C2EC3  sub         esp,270h
004C2EC9  push        ebx
004C2ECA  push        esi
004C2ECB  push        edi
004C2ECC  push        ecx
004C2ECD  lea         edi,[ebp-270h]
004C2ED3  mov         ecx,9Ch
004C2ED8  mov         eax,0CCCCCCCCh
004C2EDD  rep stos    dword ptr es:[edi]
004C2EDF  pop         ecx
004C2EE0  mov         dword ptr [ebp-8],ecx
    double solar_time, ra_base, ecliptic_aspect;
//    estimate ecliptic aspect
    m_gmt_seconds = 3600.0*(m_hour-m_daylight_savings-m_time_zone)+60.0*m_minute+m_second;
004C2EE3  mov         eax,dword ptr [this]
004C2EE6  mov         ecx,dword ptr [this]
004C2EE9  mov         edx,dword ptr [eax+5Ch]
004C2EEC  sub         edx,dword ptr [ecx+6Ch]
004C2EEF  mov         eax,dword ptr [this]
004C2EF2  sub         edx,dword ptr [eax+68h]
004C2EF5  mov         dword ptr [ebp-26Ch],edx
004C2EFB  fild        dword ptr [ebp-26Ch]
004C2F01  fmul        qword ptr [__real@40ac200000000000 (682830h)]
004C2F07  mov         ecx,dword ptr [this]
004C2F0A  fild        dword ptr [ecx+60h]
004C2F0D  fmul        qword ptr [__real@404e000000000000 (684210h)]
004C2F13  faddp       st(1),st
004C2F15  mov         edx,dword ptr [this]
004C2F18  fiadd       dword ptr [edx+64h]
004C2F1B  mov         eax,dword ptr [this]
004C2F1E  fstp        qword ptr [eax+48h]
    solar_time = m_gmt_seconds*(1.0/3600.0) - m_longitude*(1.0/15.0);
004C2F21  mov         eax,dword ptr [this]
004C2F24  fld         qword ptr [eax+48h]
004C2F27  fmul        qword ptr [__real@3f323456789abcdf (682710h)]
004C2F2D  mov         ecx,dword ptr [this]
004C2F30  fld         qword ptr [ecx+40h]
004C2F33  fmul        qword ptr [__real@3fb1111111111111 (684208h)]
004C2F39  fsubp       st(1),st
004C2F3B  fstp        qword ptr [solar_time]
    m_julian = julian_day (m_month,m_day,m_year) - julian_day (3,20,1900) + solar_time*(1.0/24.0);
004C2F3E  mov         eax,dword ptr [this]
004C2F41  mov         ecx,dword ptr [eax+50h]
004C2F44  push        ecx
004C2F45  mov         edx,dword ptr [this]
004C2F48  fild        dword ptr [edx+58h]
004C2F4B  push        ecx
004C2F4C  fstp        dword ptr [esp]
004C2F4F  mov         eax,dword ptr [this]
004C2F52  mov         ecx,dword ptr [eax+54h]
004C2F55  push        ecx
004C2F56  mov         ecx,dword ptr [this]
004C2F59  call        solar_elements::julian_day (4C2DF0h)
004C2F5E  push        76Ch
004C2F63  push        ecx
004C2F64  fld         dword ptr [__real@41a00000 (67BF70h)]
004C2F6A  fstp        dword ptr [esp]
004C2F6D  push        3
004C2F6F  mov         ecx,dword ptr [this]
004C2F72  fstp        qword ptr [ebp-270h]
004C2F78  call        solar_elements::julian_day (4C2DF0h)
004C2F7D  fsubr       qword ptr [ebp-270h]
004C2F83  fld         qword ptr [solar_time]
004C2F86  fmul        qword ptr [__real@3fa5555555555555 (684200h)]
004C2F8C  faddp       st(1),st
004C2F8E  call        _ftol2_sse (603840h)
004C2F93  mov         edx,dword ptr [this]
004C2F96  mov         dword ptr [edx+70h],eax
.................... and so on ................
O.K., if you made it this far, it should be obvious that the original C++ code has no conditional logic or loops, at least for this particular function.  And a quick look at the hexadecimal values suggests that, other than function calls into the tensor library, this whole thing only needs about 800 bytes or so.  So I am feeling very good about the possibility that this sort of thing could be run out of ROM on a custom 6502-based system, if I went that route.  But then again, maybe a 328P would be a good candidate, with its built-in 32K of Flash EPROM, and maybe just enough RAM to get the job done.  Maybe.  Obviously, I would need to look into issues of such things as how the available precision of the provided floating point libraries would affect things.  Yet there would also be workarounds for that.
Or maybe I could rewrite this in raw FORTH?
Or else you know what they say, "Travelling through hyperspace isn't like crop dusting back home", since "without branchless programming, you will never be able to simultaneously compute 500,000 objects in parallel on your GPU, as you are trying to fly through an asteroid field."
Feeling pretty good about what the disassembly looks like in any case.  So, I have gone ahead and made some revisions to the C++ source code of the solar_elements::compute_local_aspect() function.
    solar_time = m_gmt_seconds*(1.0/3600.0);
    ecliptic_aspect = fmodf(m_julian,365.242191)*(TWO_PI/365.242191);
    _vector ecliptic_aspect_vector = tensor::rotate_z (ecliptic_aspect)*_vector(1,0,0);
    ra_base = ecliptic_aspect*(24.0/TWO_PI);
    tensor SIDT = tensor::rotate_z ((solar_time-ra_base)*(TWO_PI/24.0)- TO_RADIANS(m_longitude));
    _vector local_xyz;
    polar_orientation p;
    p.m_theta = 0.0;// TO_RADIANS(m_longitude);
    p.m_phi = TO_RADIANS(m_latitude);
    local_xyz = p.get_xyz ();
    tensor ROTL = tensor::rotator(
    _vector::normalize (local_xyz.cross(_vector(0,0,1))),p.m_phi-PI_OVER_TWO
//    m_geocentric_solar_vector = m_ROTX*ecliptic_aspect_vector;
//    _vector siderial_solar_vector = SIDT*m_geocentric_solar_vector;
//    _vector local_solar_vector = ROTL*siderial_solar_vector;
    tensor GLSUN = ROTL*SIDT*m_ROTX;
    m_local_solar_vector = GLSUN*ecliptic_aspect_vector;
    polar_orientation q = polar_orientation::from_axis (m_local_solar_vector);
    m_el = TO_DEGREES(q.m_phi);
    m_az = fmodf(360.0+TO_DEGREES(q.m_theta),360.0);
Hopefully, this makes a bit more sense, and I think it may correct some issues in the earlier code.  Of course, if you look closely, there is now a place where instead of doing a bunch of vector operations where I produce a series of vectors by multiplying a series to tensors, to produce the next vector in the series; I instead precompute the product of the three tensors ROTL, SIDT,  and ROTX to produce the tensor product GLSUN, which can then be used to transform the ecliptic aspect vector to, hopefully obtain the correct position of the sun in the sky for any given longitudinal, latitude, as well as date and time.
Of course, if multiplying a tensor by a tensor in this context needs 27 multiplies, then it looks like doing this part that way will need 27+27+9 = 63 multiplications to transform the ecliptic aspect vector, whereas by doing it by performing a series of tensor by vector multiplications would only use 9+9+9 = 27 multiplications.  Yet, if there is a way to reuse the computed tensor GLSUN when computing individual planets, as a part of a more general heliocentric to local transform, then hopefully we get those multiplies back, if we can get it down to just 9 multiplies to transform each celestial vector, plus any required additions of course.  So, I think that the efficiency tradeoff is going to be worth it, besides appearing more elegant, for now.
