Making the board
A project log for typeCAD 1Hz -AI designed hardware
Making a 1 hertz timer circuit with typeCAD and AI
typecadtypecad 07/20/2025 at 14:420 Comments
typeCAD code turned the components into a KiCAD PCB. All that was left to do was position the components and connect everything.
A couple of minutes later, and this is the result.
It could use some vias and maybe the traces could be routed better, but that's what it is for now.
