My 512-bit Core Memory System
My memory is structured in 2 groups of 16x16 cores. The memory width is 2 bits, meaning 2 bits can be read or written at a time. By using several 4:16 decoders (constructed from 3:8 decoders), the desired location in the memory can be selected. Additional logic circuits were also used interface with the P and N Channel MOSFETS. Finally, a microcontroller (RP2040) was used to generate the waveforms to drive the memory and to perform tests.
Memory Tests
Several tests, including "GALPAT Test", "Half Select Current Switching Test", and "Image Writing and Reading Test" was run continuously. With a supply voltage of 3.20V, no error was detected within a period of 24 hours. This amounts to several gigabytes of data being read/written.
Mikolaj
Pawel Jablonski
Erik Piehl
