PCB designed for current roadmap.
Power consumption: Surprisingly low at full brightness ≤ 1.5W
Form factor: Board footprint significantly reduced vs previous revision
Architecture: Split into 3 modular parts for on-demand exchange
Input: Network module (e.g., WiFi or RJ45)
Processing: Decoder
Output: Display driver (supports different display types)
Next steps:
Optimize network stream for full throughput
Perform latency testing
Implement touchscreen support
Publish results in the next few weeks
gitzi
