This is a desktop small-format laser cutter that can be directly connected to Lasermaker software for use. It is primarily designed for maker education, K-12 education, colleges and universities, as well as home makers. Equipped with a 455nm blue semiconductor laser emitter, it delivers 10W or 20W laser power and is capable of cutting up to 8mm thick basswood in a single pass. Thanks to its semiconductor laser emitter adopting air cooling technology, it eliminates the need for water cooling, making it highly portable.
Details
The laser cut material supported:
The Use cases:
1, In class rooms:
2, In maker /hacker workspace:
Files
桌面小型激光切割机20W参数20250716.pdf
Product spec for 10W and 20W laser cut machines.
Adobe Portable Document Format -
130.61 kB -
07/16/2025 at 12:53
Great!
