Building the NKTg Interpolation Model
A project log for Experimental Verification of the NKT Law with Real
Experimental verification of the NKT Law using real NASA data from 30–31 Dec 2024. This model interpolates the masses of 8 planets with near
nguyen-khanh-tungNguyen Khanh Tung 07/17/2025 at 09:430 Comments
The core of this project is the NKTg Law of Variable Inertia, a physics-based model that describes how position, velocity, and mass determine an object's motion tendency in space.
We define:
NKTg₁ = x × p, where p = m × v
→ Rearranged, the formula becomes: m = NKTg₁ / (x × v)
This means that if we know a planet’s position (x), velocity (v), and its NKTg₁ (the interaction value), we can directly calculate its mass — no empirical fitting required.
This project puts this formula to the test using real-time NASA data.
