Solar Panel Project
Indoor solar power system using Victron MPPT, AGM battery, and inverter for small household appliances.
This project demonstrates a fully indoor solar charging system using a 100W Singfo solar panel, Victron SmartSolar MPPT charge controller, and Newton deep-cycle AGM battery. Power is supplied to devices via a Mean Well TS-400 pure sine wave inverter.
A custom rolling mount built from 20x20 aluminum extrusion allows optimal indoor placement near windows, with smooth mobility and adjustability.
The project emphasizes careful wire gauge selection, safe fuse placements, and compatibility with lead-acid batteries.
Tested with phone chargers. Documentation includes datasheets.
Solar Proposal 160725.pptx
Just to run it by my parents
presentation - 8.70 MB - 07/21/2025 at 05:27
Download
NPD121050.pdf
battery
Adobe Portable Document Format - 2.41 MB - 07/21/2025 at 05:27
Preview
ts400 user manual.pdf
inverter
Adobe Portable Document Format - 688.41 kB - 07/21/2025 at 05:27
Preview
Datasheet-BlueSolar-and-SmartSolar-charge-controller-overview-EN.pdf
cc
Adobe Portable Document Format - 243.46 kB - 07/21/2025 at 05:27
Preview
Datasheet-SmartSolar-charge-controller-MPPT-75-10,-75-15,-100-15,-100-20_48V-EN.pdf
cc
Adobe Portable Document Format - 278.68 kB - 07/21/2025 at 05:27
Preview
View all 6 files
