Why MQ-5?
The sensor is sensitive to LPG, methane, and propane and strikes a good balance between sensitivity and stability for typical LPG usage, making it a perfect fit for this Arduino Project.
How It Works
1. The MQ-5 sensor always monitors the air quality.
2. When gas concentration goes above a set level, it outputs LOW.
3. The Arduino reads this and triggers a buzzer and an LED.
Once the gas concentration drops, everything resets.
Tuning is done through a trimpot on the MQ-5.
Circuit Overview
MQ-5 digital output → Arduino A2
Buzzer → A0 (optional 10k resistor inline to adjust volume)
LED → A1 (with 220Ω resistor)
Powered via USB or 9V battery to Vin
You’ll also need a breadboard and some jumper wires to get going.
Code
const int gasSensorDigitalPin = A2; // MQ-5 sensor digital output connected to A2
const int ledPin = A1; // LED connected to A1 (through 220Ω resistor)
const int buzzerPin = A0; // Buzzer connected to A0 (through 1KΩ resistor)
void setup() {
// Set up pin modes
pinMode(gasSensorDigitalPin, INPUT); // MQ-5 sensor as input
pinMode(ledPin, OUTPUT); // LED as output
pinMode(buzzerPin, OUTPUT); // Buzzer as output
// Start Serial Monitor
Serial.begin(9600);
Serial.println("Gas Detection System Initialized (Digital Mode)");
void loop() {
// Read the sensor's digital output
int gasState = digitalRead(gasSensorDigitalPin); // LOW = Gas detected
// Check if gas is detected
if (gasState == LOW) {
digitalWrite(ledPin, HIGH); // Turn on LED
digitalWrite(buzzerPin, HIGH); // Turn on Buzzer
Serial.println("!! Gas Leak Detected !!");
} else {
digitalWrite(ledPin, LOW); // Turn off LED
digitalWrite(buzzerPin, LOW); // Turn off Buzzer
Serial.println("Environment Normal");
delay(800); // Delay to avoid flooding Serial Monitor
No libraries or complications, just clean logic.
Testing and Tuning
To simulate a leak, use a butane lighter (unlit). The potentiometer on the MQ-5 has to be adjusted until the alarm can reliably trigger in its presence(the system should stay silent otherwise).
If sensitivity is too much, keep tweaking the potentiometer.
Tip: Let the sensor warm up for 24 hours before tuning for accurate results.
Expandability
Once you have the basics covered.
- You can add SMS alerts via GSM modules
- Connect it to the cloud via ESP8266/ESP32
- Log gas levels over time
- Integration with a smart home system.
For a comprehensive guide, visit: https://circuitdigest.com/microcontroller-projects/gas-leakage-detector-using-arduino-complete-diy-guide
ElectroScope Archive
