So I was a quick tour at bitraf today, I got to work on the proto board that is going to connect Fan and the LED to the powersupply. I Made shure I had all the connectors I needed an startet soldering and laiyng out the components.
A small start. Here is a layout so I can see how long my wires need to be. I wanted to make it really simple to disassemble and assemble.
Øystein
