Cat Scarer
This combo fan/siren using standard parts seems to keep the cats away from my furniture.
0 followers
Device to stop cats indulging in anti-social behaviour with your furniture
https://github.com/IanDBallard/CatScarer
Project Overview
CatScarer is a Arduino-based cat deterrent system that uses motion detection, multiple deterrent mechanisms, and IR remote control to keep cats away from designated areas. The device operates using a state machine with four distinct operational states, providing both automated and manual control capabilities.
🏗️ System Architecture
Core Components
  • Arduino Nano (ATmega328P) - Primary microcontroller
  • PIR Motion Sensor (HC-SR501) - Motion detection
  • PWM Fan - Physical deterrent mechanism
  • Piezo Buzzer - Audio deterrent with siren mode
  • RGB LED - Multi-color status indicator
  • TSOP1838 IR Receiver - Remote control input
  • 3D Printed Enclosure - Professional housing
State Machine Design
🔧 Technical Implementation
State Machine States
1. WARMUP State
  • Duration: 45 seconds
  • Purpose: PIR sensor calibration and baseline establishment
  • Visual Indicator: Blue LED flickering (500ms intervals)
  • Interruptible: Yes - IR power toggle can force transition to INACTIVE
  • Logic: Monitors PIR initialization status, transitions to STANDBY when complete
2. STANDBY State
  • Purpose: Ready for motion detection
  • Visual Indicator: Solid green LED
  • Behavior: Continuously monitors PIR sensor for motion
  • Interruptible: Yes - IR power toggle transitions to INACTIVE
  • Transitions:
  • Motion detected → ACTIVE
  • Power toggle → INACTIVE
3. ACTIVE State
  • Purpose: Deterrent mechanisms active
  • Visual Indicator: Solid red LED
  • Duration: Configurable (default: 5 seconds)
  • Deterrents:
  • PWM fan at full speed (255/255)
  • Buzzer siren mode
  • Interruptible: Yes - IR power toggle immediately stops deterrents and transitions to INACTIVE
  • Timer Refresh: Motion continues to refresh activation timer
  • Transitions:
  • Timer expires → STANDBY
  • Power toggle → INACTIVE (immediate stop)
4. INACTIVE State
  • Purpose: Device disabled, ignores all PIR input
  • Visual Indicator: Solid yellow LED (red + green)
  • Behavior: Completely ignores motion detection
  • Interruptible: Yes - IR power toggle transitions to STANDBY
  • Use Case: Manual disable for maintenance, testing, or temporary deactivation
  • Cat Scarer Release History
    ian Ballard • 07/25/2025 at 15:56 • 0 comments
    • V1.0.0: Initial release with basic functionality
    • V1.1.0: Added state machine refactoring
    • V1.2.0: Enhanced PIR sensor and PWM LED control
    • V1.3.0: Added inactive state and IR remote control
    • V1.4.0: Fixed IR library integration and cross-platform support
View project log
View all instructions
